Sym. Wing Building Tip
TN
RE: Sym. Wing Building Tip
It worked out great. This technique was used in Project: Corro Wonder. About four pages down. You may want to take a Look. The strenght is in the yardstick. If you have ever built a sym. wing, then inserted the yardstick, you know it can be a bi*ch. CA'ing is a bear too. Takes a lot of the hassle out of the building.
Sure takes the hassle out of lining up the spar after inserting it, especially for tall spar/funfly applications. I'll have to try this one out soon.
TN
Never seen an AIRCORE. I didn't think I was the first one to every use this technique or think of it. Its so simple. Just don't remember seeing it posted in all the time I have followed the SPAD craze. ENJOY.
TN
I haven't tried this on a flat bottom wing. Someone mentioned AIRCORE did this. Are AIRCORE wings flat bottomed or sym. But anyway, you would have to put the yard stick inside the wing before gluing to get the top wing guide measurement. More distance on top then the bottom. (Everyone knows this) Once this is done, the guide strips could be glued in. Then glue the wing(TE). Then,HOPEFULLY, the yardstick SHOULD slide into the guides. Why not give it a shot and let us know.
Enjoy
Enjoy
I tried this wing idea and it works great. Mine was a very tight fit and just as RC Wings said...no glue need for spar. BTW, I did it on a all 2mil sym. wing. Now all I need is a fuse to put it on.
RCWings , last summer I made a spar jig to hold down and space my spars on the flat bottom wing designs. It works so good that I can fold and glue in minutes of having the wing cut to shape. Picture an "E" cut out of 3/4" plywood face down and cut to fit and hold a yardstick or 2 yardsticks at the same time. Easy jig to build and works great. If anyone wants pics I will post them.
