S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Bolts and Screws
Old 01-04-2004, 03:02 PM
RichD
RichD's Avatar
Default Bolts and Screws
Lookig at all the pics of the spads, i noticed one thing. All the bolts and screws are stickig out the sides. Why not use your cutoff disc and chop them off? I am sure the weight reduction would be significant?
Just a though.
Old 01-04-2004, 03:31 PM
Madd_Maxx
Default RE: Bolts and Screws
There is only one reason why I don't cut them off.....I'm to lazy I normally just buy the screws and bolts for my spads by the box at the local hardware store.....they are cheaper by the box and you never know when you might need another one. I only get bolts that will work in several different places (axle bolts - motor mount bolts) that way I don't have boxes of 5-6 different size bolts just sitting around.
Madd_Maxx
Old 01-04-2004, 04:48 PM
Woodsy
To lazy
Old 01-04-2004, 04:51 PM
Chunky C
Fat and Lazy. Beside the weight reduction on a 4-5 lb bird would be negligible.
cc
Old 01-04-2004, 09:22 PM
flipa10
Sometimes when you use the cutoff tool to cut bolts/screws that are in poly cutting board parts, it loosens the hole because of the heat of the cutting wheel, especially for engine mount screws. Nothing that bolt cutters, dikes or a hack saw can't take care of.
Flip
Old 01-05-2004, 10:36 AM
mustangman177
Rich D
I do cut off the ends of the screws and bolts that do protrude through on my PBF's The reason being, they could easily cut-rip through your fingers hands while handling them (I know !!!), especially while hand launching them
It only takes a few seconds to do this with a dremel cut off wheel. I don't do it for the weight factor, but rather saving my skin.
Take care.
Cary
Old 01-05-2004, 09:03 PM
Todd D
My Feedback: (51)
Todd D's Avatar
It's tough to reuse them in a self tapping situation if you cut the ends off. Who wants a bunch of useless screws lying around? HeeHee.
Old 01-18-2004, 04:05 AM
suitcase
suitcase's Avatar
Cutting them with the dremel tool will really loosen up your fit. I just clip off the end with dikes. I also use only the 1/4" hex head screws, (bought by rvator) and use the bat drill. So easy.
Old 01-18-2004, 09:18 AM
fritch1969
does anyone use aluminum pop rivets ?
Old 01-18-2004, 08:06 PM
RVator
I used some to attach the bracing wires on the tail of my 60 size Deb. I used a washer on the back side of the rivet. Its hard to set the rivit without deforming the coro through.
