Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
 M.K.  1 SPITFIRE from you won't believe its coro >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 02-23-2004, 11:27 AM
  #51
canadianice's Avatar
Default RE: RE: M.K. 1 SPITFIRE from you won't believe its coro
Just a few shots of My planes from Mikes Kits by the way I'm test pilot for the project and you guys will love I mean love these planes. After the first flight I begged Mike for the plans which he didnt have so I went over and copied onto onion skin and went to work and was it worth it!!!! I posted a little bit on how I finnish the Corro on the spad forum [corro to a new level] if there is interest I will do a pic demo on our newest project the ta152 on how to cover with card stock
ID:	104153   Click image for larger version
ID:	104154   Click image for larger version
ID:	104155   Click image for larger version
Old 03-23-2004, 04:46 PM
  #52
Default RE: M.K. 1 SPITFIRE from you won't believe its coro
Sorry for being gone so long, the camera is out on loan. The fillets are just a standard fillet with a bottom glued to the fuse then just two small formers and then bristol board glued on in 3 sections to simulate the 3 piece alluminum fillets on the real plane. Only putty used is on the underside rear behind the wing. Should be able to finish the wing sometime next week, as I will be needing it shortly.
Old 08-05-2008, 10:19 AM
  #53
Was this ever updated from 2004 i have been unable to find anything
has anybody found/figured out the rest of the build
I am in the process of building this and would appreciate any help especially the fuzz design and location of servos
regards Steve
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
