S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
my qhor
Old 01-17-2004, 11:30 AM
miskin
Default my qhor
hi guys i got a bit bored last week so i thought i would build myself a qhor
then i took it to work today and painted it (i work for peugeot in the bodyshop) so paint is not a problem
the spec is
magnum 36xl for the engine 11x4prop
futaba 3003 servos
6oz tank
10%nitro
if you notice in the pictures the wings have bowed a bit when i baked it in the oven at work[:@]
will this cause a problem??
any comments welcome
ID:	91411   Click image for larger version
ID:	91412   Click image for larger version
ID:	91413   Click image for larger version
Old 01-17-2004, 12:05 PM
Sewerdude
My Feedback: (20)
Sewerdude's Avatar
Default RE: my qhor
You baked it? Coro and oven heat dont get along. Might be a handfull to fly with the tips down like they are.
Old 01-17-2004, 02:48 PM
Zombie
Zombie's Avatar
Default RE: my qhor
I don't have enough experience to tell you about reverse dihedral - which it looks like the downward bow would probably mimic. But, in my thoughts, the bow may/might cause a bit of aileron binding - if the trailing edge is bowed.
Old 01-17-2004, 04:05 PM
miskin
Default RE: my qhor
ok thanks for the feedback
the TE has not warped its only the LE that has ..thats what happend when i baked it for 15minutes at 80o C (just a habit when you paint cars all day long)
anyway ive heated up the LE with a hair dryer turned the plane upside down with weights on the tips and so far its seems to be better
if the weather stays nice it will be flying tommorrow i will let you know the out come
Old 01-17-2004, 04:11 PM
3d-aholic
My Feedback: (7)
3d-aholic's Avatar
Default RE: my qhor
Maybe turn it over and bake it again....
Try and take it out when its just right...
(And, I'm serious !)
Old 01-17-2004, 05:09 PM
red_guy
Default RE: my qhor
is that hard wood engine mount? cause fuel has the bad habit of getting into the wood. u have to put some lacquer on it or something.
anyway, nice looking plane. i have a qhor too. where did u balance it? mine i had to put a aluminum engine mount to be able to balance at the wing fold as in the plans.
with the hdpe engine mount (well mine was ldpe and it snapped at the first crash) it was a bit tail heavy and didn't fly well. i crashed it a couple of times until i built the aluminum engine mount and now its just fine
ReD GUY
Old 01-18-2004, 02:42 PM
miskin
Default RE: my qhor
well i flew the qhor today along with my spa3dt and i must say the qhor flew fantastic i loved every minute of it
now my spa3dt flew fine apart from when i try to bring it in nice and slow to hover it starts to wobble []...my friends does not just mine
we tried loads of different things like moving CG and more reflex but it stays the same ????
it flat spins really well infact the best ive ever done
the spad is built to plan apart from the engine mount which it made of 3/4 plywood
any advice welcome
