Heavy SPAD???
NC
Built a SPAD about 8 months ago, and self taught myself to fly. The problem I am having is, the plane flies beautifully, but when landing, if the power si cut back too much it drops like a rock. The cg comes out right, but I'm afraid it's too heavy. Is this comon with spads? The wing is a 4mil, 60 inch dihedrahl, with a 2.5" downspout fuse. The tail feathers are also 4 mil....I just cut a 60" foam wing for it and need to finish to try, but any suggestions would be greatly appreciated.
[link]http://www.tapeinos.com/AirplaneStuff/index.html[/link]
No, it's not comon, either the wing loading ( weight v's wing area) or the cg is way out.
all 4mm is not a good idea, try and get some 2mm as well especialy for the wing
a SPAD or any othe plane flies, glides, performes EXACTLY the same as a plane built from any material if the numbers are OK
My Feedback: (21)
You used the heaviest possible materials to build the plane. Of course, they're the most available... There's nothing heavier than that vinyl downspout material. It adds at least a pound to the plane.
I've built a couple of trainers completely out of coroplast over the past year. Both came in right around 6 pounds, and float on landing. There were two ways I saved weight:
1. Built my own "downspout" out of 4mil Coroplast and strip of 1/8x1/4 spruce.
2. Built a "RNAF" style wing with a 4mil base and 2mil top.
These places can help with supplies:
[link=http://home.comcast.net/%7Etipstrickslinks/sup_coro.htm]http://home.comcast.net/%7Etipstrickslinks/sup_coro.htm[/link]
DC
ORIGINAL: jbronco74
MT
You don't "have" to have a two mil wing for the Deb to be a good flyer. The original deb had a 4 mil wing, 4 mil tail-feathers, and gutter downspout fuse. I heard tell it weighed-in around 6 lbs, 14 ounces and flew (and landed) just fine.
Check the weight of your plane. That's the only way you'll know if it's heavy. And if it's the one I see at your website, you might consider getting rid of some of that metal on the monster landing gear - if you need to lose a bit of weight. I drilled mine out and dropped a couple of ounces. You could easily drop more being you could drill larger holes than I did. See it at the bottom of the thread at: [link=http://spadworld.net/viewtopic.php?t=6361]Birth of a Bubonair.[/link]
Check the weight! As Mike stated, if you are under 7 lbs you should have a good flyer. So if you have problems after that, maybe you're throttling back too much for landing.
