SPA3DEFI-PROFILE-Flight Report & Pics
#76
MI
RE: SPA3DEFI-PROFILE-Flight Report & Pics
Novabill, I’m in the process of building a plane similar to your design, just need to get to the LHS for parts to finish. In the process I cut new tail feathers, borrowing your design using counter balance controls, for my QHOR. I flew it the other day and the counter balances on the elevator failed, folding back, breaking the bamboo skewers used for strengthening measures.
Just curious what you have done to prevent this?
Also can you post those pics and the Cad you mentioned?
#77
NY
ORIGINAL: SDR-Hammer
#78
Your wing is perfectly flat-top. Does this have any different flight characteristics than the SPA3D wing as illustrated on spadtothebone?
Also, what do I as for when looking for the fuse material? Doing a web search brings up every shape and form known to man, besides the nearly square tube that you used.
#79
NY
ORIGINAL: gasrc
No incidence problems. You do'nt have to reflex the ailerons up to get it to fly straight and it stays trimmed out within a broader speed envelope.
#80
Thanks.
1 mo question
What do I ask for when looking for the fuse material? Doing a web search brings up every shape and form known to man other than the nearly square tube that you used.
1 mo question
#81
NY
Tractor supply is where I get mine, do you have one of them locally. Electric Fence Post Insulator is what we call it. It is spaced between the main posts of an electric fence
#82
ORIGINAL: novabill
How about a pic of the raw material, please (as purcahsed)? That way I can just print it and show the salespeople rather than having to unproductively explain it.
All I can find is stuff like [link=http://safefence.com/Hardware_Insulators.htm]THIS[/link]
#83
MI
Thanks for the info. It could have been the way I cut the tips, tried to get a little fancy and probably got some flutter.
That’s what I like about these planes, try something out if it doesn't work cut new pieces, less than five minutes back in business again.
#84
Here is how i got rid of the music wire to hold the air foil, i took a piece of 4mm and cut it 12 flutes wide by about 2 inches long, bent it into a u shape and used 3m vhb tape to stick it in. I put on at the end and one in the middle of each wing, seems to work good, and no music wire.
#85
NY
ORIGINAL: gasrc
ORIGINAL: novabill
#86
Thanks. That will be great.
That must have been some crash to damage the front and the rear! What happened?
In one of your new crash pics, it appears the insulator is 1 x 1.5 solid. Or is that just the remains of your engine mount stuffed in the tip? I assumed it was square(ish) tube.
#87
NY
ORIGINAL: gasrc
I will be giving the plane to my good friend Alex in june, as I am starting a new improved plane "The Coro Katana" with a foam fuse and symmetrical wing. I did'nt get to TSC today, hopefully I can go by in the next two days.
#89
NY
ORIGINAL: gasrc
Hey bill. Did you ever get pics and info on that fuse material?
sorry man. I will get on it asap
#91
NY
I took on a new job at our other store and have been slammed for the last week. Things are slowing down a little, so if you still need info on the EFI, I should be able to run by TSC tomorrow. Sorry for the delay.
#93
NY
Here's a link to the TSC site. The fuse material is called Poly Batten and measures 1 1/2 x 1 1/8 x 49". there is no picture available, but it can be ordered from here.
http://www.mytscstore.com/detail.asp...productID=1627
Sorry about the delay.
I will be starting a new project verry soon, so keep your eyes open.
