S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Coroplast hinge broken
Old 03-16-2004, 09:04 AM
dickj
dickj's Avatar
Default Coroplast hinge broken
I have crash damage adjacent to the aileron control hinge thru the hinge line. The inge line is split for 2 inches at this point. Any suggestons how to repair such a problem? I am sure I cant remove the aileroin from between the two wing halves and dont know quite what to do. Any suggesitons appreciated.
(first spad trainer for my grandsons to learn to fly)
Old 03-16-2004, 12:01 PM
SeacretsOceanCity
SeacretsOceanCity's Avatar
Default RE: Coroplast hinge broken
I have used wire ties works fine
Old 03-16-2004, 12:17 PM
Mighty Mouse-RCU
My Feedback: (145)
Mighty Mouse-RCU's Avatar
Shoo goo works pretty good for a while. Keep surface clean before you use.
Old 03-16-2004, 02:18 PM
bulletbob
I have had some damage from rubber bands when wing is torqued during crashes or landings (mine look the same). I use small zip ties between aileron and wing near body and problem goes away. Looks ok too
Old 03-16-2004, 05:10 PM
kramer
My Feedback: (61)
kramer's Avatar
Get some 2mm and cut it to about the size of a CA hinge but a little longer.fold it in half across the flutes,and glue it in.You won't have a rubber band tear through again
Old 03-16-2004, 06:19 PM
Cjsworks
What ever you choose to do as a repair at least drill a hole at the end of that split to keep it from traveling further.
Old 03-16-2004, 07:32 PM
Flypaper 2
Pumch a hole in both surfaces. Stick a Robart hinge point in with Goop and your good to go.
Old 03-16-2004, 07:59 PM
Oatmeal
I've used vinyl adhesive with good result. Take ~1inch wide strip and apply 1/2 to control surface and 1/2 to wing, making sure to have the surface flexed to the maximal travel before application. Assuming that the surfaces are clean prior to placement, this is a very secure and easy method.
Many other methods have been described.
Check these out...
[link=http://www.rcuniverse.com/forum/m_1517714/mpage_1/key_hinge%252Cmethod/anchor/tm.htm#1517714]RCU thread with pics[/link]
[link=http://spadworld.net/viewtopic.php?t=1498]Spadworld #1[/link]
[link=http://spadworld.net/viewtopic.php?t=6638]Spadworld #2[/link]
Old 03-17-2004, 08:43 AM
dickj
dickj's Avatar
Thanks fellas for all of the neat ideas and they came in so fast too--------
I really appreciate them and have my aileron repaired and ready to fly this morning.
Old 03-25-2004, 09:53 PM
LUDS96
My Feedback: (23)
I Usually glue a regular hinge on top of the split. Works well. My next one I'm going to glue the hinges on to start with.
