S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Proper Antenna Placement
Old 03-17-2004, 06:08 PM
Cjsworks
Default Proper Antenna Placement
Ive seen alot of pics of flyers putting their antenna wire into the flut on the horizontal stab. Will this decrease your range from being inside the coro?
Old 03-17-2004, 07:35 PM
Tattoo
Default RE: Proper Antenna Placement
I've been doing it for 6 years no problems. In fact, on my Spa3d's, the entire antenna is inside the wing flutes, no problems
Old 03-17-2004, 08:42 PM
Trombe
As long as it stays away from metal you will be fine
Old 03-17-2004, 09:03 PM
steener
and stay away from servo leads.
Old 03-18-2004, 05:48 PM
red_guy
it will do just fine. the plastic dont block the radio waves. in fact it is better because the flute will protect the antenna in case of crash.
im using it like that on my qhor and never had problems
red guy
