S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Wing jig
Old 03-30-2004, 12:53 PM
Fliptunes
Default Wing jig
I am getting back into building SPADs and I need to make a wing jig so I can get some nice looking wings. For the life of me I can't seem to find the post I am looking for. Perhaps one of you guys knows where it is at. It was a wing jig post that had pics of this jig. It was a table top jig that was hinged. there was a piece of plywood with a dowel glues to it it make a nice rounded edge. Basicly you put the coro in and then pulled down on the handles bringing this doweled plywould down onto a 2X4 with a routered groove to fit the dowel. Of course you heasted the coro a bit and it bent smothly. It seemed like a very slick design and I want to try it out. Anyone have any information on this jig. I know it is a bit vauge but the mind is the first thing to go right. Please let me know.
Fliptunes
Old 03-30-2004, 01:10 PM
upnflyin
Default RE: Wing jig
http://spadworld.net/viewtopic.php?t...wood+dowel+jig
If I copied right this should be the one you wanted...... good luck
Al
Old 03-30-2004, 01:13 PM
Dale Chesak
Dale Chesak's Avatar
Check these out - Wing jig -
[link=http://spadworld.net/viewtopic.php?t=5314&highlight=jig]http://spadworld.net/viewtopic.php?t=5314&highlight=jig[/link]
[link=http://spadworld.net/viewtopic.php?t=5881&highlight=jig]http://spadworld.net/viewtopic.php?t=5881&highlight=jig[/link]
Old 03-30-2004, 01:34 PM
Fliptunes
Thanks upnflyin. I guess I should have put the dowel in my search lol. That is exactly what I was looking for.
Old 03-30-2004, 02:31 PM
upnflyin
your welcome fliptunes. If you use it let me know how it works out. I remembered seeing it but never got around to trying it. Have been using rnaf wings so far. Drop me a pm is you liked its outcome.
Al
Old 03-31-2004, 08:02 PM
Deadeye
Deadeye's Avatar
Here's what I do. It's adjustable, uses only four clamps, and can be disassembled so I have full use of that table. It can also be used for flat bottomed or symetrical, just shim up the tip for symetrical. I also measure it so the hinge line meets teh edge of the table, this ensures I have all teh control surface movement I need.
ID:	117355   Click image for larger version
