bashed spa3d???
SD
bashed spa3d???
ok... i am in the process of making a SPA3D but i have a bit of a problem, of cource! it says to use a 36" wing the coro i have is only 32" what should i bash on the "plans" to make this work?? make the alum tube 32 also or not? and do you think it would have "too much power" with a LA.46 or should i go to a .40? power is nice, heck is it even possible to have too much power!?
if i have any other questions i will post them
PA
RE: bashed spa3d???
For a 32" span, you might want to take a look at the [link=http://www.spadtothebone.com/SPAD/PQHor/PQHor2/pqhor2.html]PQHor[/link] instead of the SPA3D. The PQHor flies just like the SPA3D only it's a tad bit smaller and the 46LA should work on it. I had a TT GP42 on my Qhor (no profile) and it worked well.
Hope this helps,
Hope this helps,
My Feedback: (9)
RE: bashed spa3d???
The first SPAD3D I built. I cut the hole for the fuse in the wrong spot. I just cut off the other end of the wing and left the rest like the planes call for. I now am on my 5th one. They all fly a little different. The 32" span one flew about the same as the others. As far as your power question. I run a ST.45 on mine. I wish I had a ST.51 or OS.46AX. It could use a little more power.
Be sure to run a low pitch prop. These things don't like speed. I run a MA 12x4. The APC 12x4 and APC 12.25x3.75 are also great props. They are just to easy to break. Props are the biggest cost on one of these. My first 20 flights cost 15 or so props. At $5.00 each the APCs were just to high. TheMA are $3.25 each.
DAvid
DAvid
My Feedback: (9)
IN
RE: bashed spa3d???
I have done exactly what you're looking to do. I have a spa3d with a 32 inch wingspan and a 32 inch long rail. Take the spa3d plans and shrink the tail feather dimensions by 25%. Build it with the elevator and rudder hanging off the back of the fuse, this will increase your tail moment and help make it more stable in the hover. For power, I went with an OS 32 SX. I also used a AAA NiMh pack to keep weight down. I used a 6 oz tank and the empty weight of this airplane is exactly 3 1/2 lbs. It will hover at half throttle and has a much better glide ratio than a qhor. If you have a bushing .46, you may take a little weight penalty, but you should still have enough power to have some fun. Let me know if I can help further. Another option would be to use the qhor dimensions but use the spa3d wing, I believe it to be a superior design over the qhor's wing.
SD
RE: bashed spa3d???
ok so i use a .40 instead of the .46?.... and it will still be able to hover?
i think i can make this work.... well i think i know i can make this work!....
thanks guys
thanks guys
FL,
RE: bashed spa3d???
Well, I'm probably too late, but my 2 cents... I had the same problem ( Pepsi signs only 32" wide ) used 32" channel, all other dimensions the same. I wound up putting a SuperTigre G-51 on mine. It works fantastic. Just take it easy on the throttle.
SD
RE: bashed spa3d???
easy on the throtle! wuts fun about that!?
and no ur not too late, im still workin on it and only got about half the build done but i will get there sometime!.......
later
later
RE: bashed spa3d???
Use the 32" fuse and the 46la. You'll want the extra power for pulling out of hovers. These planes are a blast to fly. The Spa3d wing is better than the Qhor in my opinion also.
