hey guys total noob here as to spads..
AZ
hey guys
i have a 40 LA sitting around and i wanna attempt building a spad..
i want to use the 40 la of course..
i am curious if anyone built a 40 size pizza box flyer..
just the square box
thanks
Felix
just the square box
thanks
Felix
AZ
RE: hey guys total noob here as to spads..
im also looking at the QHOR..
it was made with a TT 42 GP...
and can u spray paint coroplast with paint made for RC ??
Felix
EDIT : also..i am looking at the plans for QHOR ....i have the 40 la...would a 40 inch wing span be perfect??? also
what is an aluminum stock????
Felix
Felix
Felix
I am just about finished building a QHOR 40. The aluminum stock refers to bar stock used to make the landing gear. I used some spray can paint on the bottom of the wing and horizontal tail so I can see if it is right side up or not. It went on OK. If it flakes off I won't be upset. I will fly it with an ASP 46 engine. If the QHOR works out I have the stuff to make a SPD3D for my next adventure.
Felix,
From what I've read, a Pizza Box Flyer would be great fun. If you go with a QHOR or Spa3D (I recommend the latter), use a 32" wingspan and 32" aluminum rail with your OS .40 LA instead of the standard 36" wingspan/36" rail.
SC
SC
AZ
which one should i build..
a pizza box...or i mean a ciggy pack for my 40la..
or a SPA3D????
i am only on my second balsa plane..even though i can hammerhead it and knife edge etc......
thanks guys
Felix
or a SPA3D????
thanks guys
Felix
DC
ORIGINAL: Felix21685
you dont think it would be too heavy ?
