S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Problem with Gnat
Old 05-09-2004, 04:36 PM
air mail rcu
Default Problem with Gnat
Need some advise. On the maiden flight my gnat wants to tuck under or loop with power on. With motor off it seems ok. Has anybody had this problem before. The CG is about 3.75.
Terry
Old 05-09-2004, 08:07 PM
Barland
Default RE: Problem with Gnat
We are flying a bunch of Gnats in my area, most with the CG at 3 3/4 inch. They are flying pretty well. Do you have the ailerons pulled up so that the bottoms are AT LEAST even with the alum. channel bottom? If you want take a look at the article at [link=http://www.wildwingscombat.com]Wild Wings Combat[/link] for info on what we are doing. The Gnat is great for club combat as a starter plane for combat. Most here are using the OS 15LA with the 8 X 3 combat prop spinning at 17,500 rmp. Hey Good Luck! DickB
Old 05-10-2004, 06:30 PM
bhole74
bhole74's Avatar
raise your ailerons a bit above the bottom of the fuse.
Old 05-10-2004, 08:54 PM
air mail rcu
The ailerons are even with the bottom of the fuse. I will raise them a little and try it again. Thanks DickB and bhole74.
Old 05-16-2004, 08:31 PM
air mail rcu
Thanks Guys I moved the CG forward a bit and adjusted the ailerons like you said and it flys GREAT.
Thanks again
Terry
