Spad-gic Extra - - Spa3d
UT
RE: Spad-gic Extra - - Spa3d
For the stripes on the bottom of the plane I used Zagi Tape Black/White over the top of white Krylon to keep the paint from flaking off and to allow the white tape to show white through instead of the red Coro. One thing that I like about the tape is how much more stable the wing is. It doesnt flex near as much as it did before while in higher speed dives. I think If you covered the wing on both sides at two different angles or even at a diagonal it would make the wing even more rigid.
