S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Gas Spad
Old 05-31-2005, 11:39 PM
CigarSlicer
Default Gas Spad
Anybody tried a gas SPAD? I've got a 25cc Homelite sitting unused that needs to be flying.
Old 06-05-2005, 04:29 PM
mdavies31
Default RE: Gas Spad
I have a 80" DPS with a Ryobi 31. I used a 4"x4" fence post for the fuselage, the wing is 4mm and 2mm Coro DPS type construction.
It's not got much vertical but flys great.
Old 06-05-2005, 05:09 PM
mdavies31
Here's some pictures of my Ryobi SPAD.
ID:	280767   Click image for larger version
ID:	280768   Click image for larger version
ID:	280769   Click image for larger version
Old 06-06-2005, 12:03 PM
Smooth Spanky
Smooth Spanky's Avatar
Mdavies31:
That looks great! Were you able to buy the motor itself or did you have to buy a weekwacker? How about the motor mount?
Thanks.
Old 06-06-2005, 04:06 PM
mdavies31
Got it from ebay, already to fly. converted using JAG parts.
http://jagengines.com/
More info links:
http://www.geocities.com/CapeCanaver...216/index.html
http://www.geocities.com/CapeCanaver....htm#ryobi.htm
http://www.wackerengines.com/index.htm
http://www.paragonaero.com/ryobi.htm
Old 06-06-2005, 06:59 PM
Deadeye
Deadeye's Avatar
Here's mine; 8 feet and 25 pounds of coroplast, yardsticks, polyurethane glue, and gear. 35cc Quadra, 52 oz tank. I can fly her for 1 1/2 hours between refuels. I don't get great vertical either, but it's still a blast to fly it. Flys smooth, and the wind doesn't bother it much. I've got flaps and a bombay door. I can fit a coffee can of candy/assorted treats in her bombay.
ID:	281341   Click image for larger version
Old 06-12-2005, 10:58 AM
pcjohnson_ohio
This one hasn't flown yet, have to finish installing the radio
86" span, 16 lbs, Ryobi for power
Pete
Old 06-14-2005, 09:11 PM
doityourself
what servos and radieo are you guys using.
Old 07-05-2005, 12:51 AM
Marlowe
Marlowe's Avatar
Mdavies31,
Your plane is very similar to what I have started to design. I have the 4" fence post and it weighs a ton. What is the length of your fuselage? Also what is the total weight of your plane? I'm shooting for 17 pounds and a wing area of 14.32 ft2 for a wing loading of 19-oz/sq. ft., but the weight of the 4" post has me concerned. Scaling up the Debonair gives a fuse length of 66 inches, but I'm afraid it will be too heavy even with Swiss cheesing it.
Your thoughts would be most appreciated
Old 07-06-2005, 07:13 PM
sirrob01
http://spadworld.net/forum/viewforum.php?f=11
should give you all the info you need on gas spads as well as a few plans.
also lookup ultra spadstick on the free plans page of the main spad site
S01
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
