S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
"ML Spattern"
Old 08-13-2005, 09:38 AM
Omaha_RC_Flyer
Omaha_RC_Flyer's Avatar
Default "ML Spattern"
I have been toying with the Idea of building a Spad pattern plane. Acam had also mentioned doing it. I would love to fly it at a competition and beat some of those $2500+ planes! Attached are pictures of my prorotype fuse and wing taped together. The fuse will have foam formers in it, like the one in the picture, where the turtle deck starts. I may move the gutterpipe motor mount former up a little bit, so it will be in the center line of the fuse. I will probably do a plug in wing design of some sort. The wing is slightly swept and it will have a tapered airfoil. I will be using foam ribs in it, to give me the tapered airfoil (bigger at the root and smaller at the tip). The fuse and the one wing weighs 2.5 lbs. as you see it. Granted there will be more weight added do to the addition of formers and such. If it turns out to be a good design and flier, I will start a build thread with detailed photos. Since There is a spad already named "Spattern" I dub this one "ML Spattern"
Specs
Wing
66" Wing Span including fuse width
31 1/4" Individual wing length
17 1/2" Root Chord including aileron
10" Tip Chord including aileron
Fuse
60" Fuse length
67" Fuse length with YS 1.20
Vertical Stab
6 1/2" width at top of vertical stab
19 1/2" width at bottom of vertical stab (part is unseen inside the fuse)
10" tall vertical stab
5 3/8" width at bottom of the rudder from the hinge line
3 3/8" width at top of rudder from hinge line
Horizontal Stab
24" wide
8 3/4" root chord
5 5/8" tip chord
split elevator with a 1 3/4" space between the two
2 5/8" at root from hinge line
1 5/8" at tip from hinge line
ID:	309550   Click image for larger version
ID:	309551   Click image for larger version
Old 08-13-2005, 09:43 AM
Smooth Spanky
Smooth Spanky's Avatar
Default RE: "ML Spattern"
Omaha:
Looks fantastic. Keep the pics and the details coming!! Good luck.
Old 08-13-2005, 09:45 AM
Omaha_RC_Flyer
More photos!
ID:	309553   Click image for larger version
ID:	309554   Click image for larger version
Old 08-13-2005, 09:54 AM
Omaha_RC_Flyer
A few More!
Wing root and tip
ID:	309559   Click image for larger version
Old 08-13-2005, 10:36 AM
moparcolt
I would love a set of plans for this. I wuold like to build a scaled down version that I could fly in the firld behind my house. I already fly a small rail spad with a .25 bb motor on it back there but I would like something that looks more like a plane. I can't wait to see the finished product!!!
Old 08-13-2005, 05:32 PM
acam37
My Feedback: (16)
acam37's Avatar
Hey, that looks good. I hope you see this one to the end. Thats my problem,I start a project then lose interest and give up on it. I really want to build a Spad Ultimate,but I just can't get the motivation to start. I have the whole project figured out in my head but that is as far as I got. Just keep us all updated on your progress.
Old 08-14-2005, 11:40 PM
Omaha_RC_Flyer
Acam,
I incorparated some of the things I learned from building my two spad Extras (i.e. part of the fuse, turtle deck, etc..) It is neat how you can apply techniques learned from other spad builders, to your own designs. It may be a little while before I finish this one. I'm having to much fun flying my 31cc Ryobi UltraSpadStick.
On its maiden flight, the needles were set very rich and I was using a MAS 18X6 prop, the power output sucked[:'(]. It was all it could do just to stay aloft (very slow). So I changed the prop to a wood 18X8 zinger and tinkered with the needles, which gave me 700 more rpm. Man did it come alive. Still lacks in the vertical department (about 100 to 150 ft. before it stalls), but it is really fun to fly. I'm going to try an 18X8 APC next, when the LHS gets some in. The Ryobi engine is actually quiter than some of my two stroke nitro engines.
Later,
Omaha
Old 08-20-2005, 12:59 PM
acam37
My Feedback: (16)
acam37's Avatar
Just keeping the post alive. Maybe Omaha_RC_flyer will get the hint and finish this plane ASAP so we can see the final product. He's probably tied up with those flying race cars. LOL
Old 08-21-2005, 11:20 PM
Omaha_RC_Flyer
Acam,
It is funny you say that, our club had it's unusual aircraft fun fly, yesterday (08/20/05) and all the cars and the ambulance flew except one car (it was too nose heavy), . We hope to have all 8 cars and the ambulance in the air at one time, at my club's labor day air show this year.
Once it is over, and after the spad fun fly here in Omaha on September 10, things around here should calm down a bit, so I can finish the "ML Spattern".
As I mentioned before, I'm having a lot of fun with the 31 cc USS. I installed a $30.00 smoke system in it yesterday before going to the fun fly. I followed this [link=http://www.rcuniverse.com/magazine/article_display.cfm?article_id=455]article[/link] and used a $14.00 windsheild washer pump, with a servo activated micro switch. It works great. I still need to adjust the flow, but all in all, I was very impressed. I'll try to post some photos of it, while in flight and smoking. Look for a new thread about it in the near future.
Later,
Omaha
Old 08-22-2005, 09:19 PM
RC-Captain
RC-Captain's Avatar
The smoke set up is cheap already without using a 9 dollar winshield pump which would be to heavy for the planes I fly. Having said that I don't understand why they cant develope a servo that is a switch already to eliminate using both a servo and a seperate switch ? I mean for the love of PETE this isn't rocket science.
GL with your smoke Oh'
Old 02-23-2006, 09:27 AM
Omaha_RC_Flyer
Most of you probably thought this thread was dead. Well I have been on the foamy kick lately, and have given building spads a break. Wait a minute, foamies are considered spads to aren't they? Attached are photos of my progress on the ML Spattern. Still trying to work out a plug in wing design. I have also started creating Building instructions/plans similar to the ones seen on [link=http://www.spadtothebone.com]www.spadtothebone.com[/link] in the plans section. I'll give a sneak peek of a few photos I have in the instructions/plans I'm working on.
Picture 1. Parts laid out ready to assemble
Picture 2. Formers and tail feathers glued in
Picture 3. Fuse almost complete, Still need to make a fiberglass canopy and cowl.
Picture 4. Fuse with cowl plug
Picture 5. H. stab
Picture 6. V. stab
Picture 7. Forward fuse
Picture 8. Aft fuse
Picture 9. Turtle deck flute cut outs
Picture 10. Turtle deck Dimensions
Picture 11. A former
Later,
Omaha
ID:	413983   Click image for larger version
ID:	413984   Click image for larger version
ID:	413985   Click image for larger version
ID:	413986   Click image for larger version
ID:	413987   Click image for larger version
ID:	413988   Click image for larger version
ID:	413989   Click image for larger version
ID:	413991   Click image for larger version
ID:	413992   Click image for larger version
Old 02-23-2006, 01:17 PM
Spadinator
COOL.....Waiting patiently
Old 02-23-2006, 09:26 PM
The_Pipefather
Great going, Omaha Flyer!
Waiting for the finished plans too. I think you should give the foamies a break for a while (until the plans are done, that is )
Anyway, by what factor do you think I should multiply this to power it with a .40 class engine?
Old 02-23-2006, 10:12 PM
Omaha_RC_Flyer
ORIGINAL: The_Pipefather
Not sure, I'm going to power this one with a YS 120, maybe Chris or some of the better spad builders, might be able to help you out on that one.
Later,
Omaha
Old 02-24-2006, 01:11 PM
Spadinator
Times the dimensions given by about .75-.70. That should give you something close to a .40 size plane!!
Old 02-24-2006, 02:07 PM
Omaha_RC_Flyer
Thanks Spadinator!!
Omaha
Old 02-24-2006, 03:30 PM
Spadinator
No Problem Omaha!!! Your build looks great!!! I was hoping for a .40 size pattern to try out. This looks like it could be the one[X(]
Old 02-24-2006, 07:04 PM
MrGreenSpeed
I can't wait
I have a new ringed OS.61RF, fitted with the fuel pump, 86 carb and tuned pipe, like the Hanno special, just waiting for a SpadPattern ship[8D]
Jeff
Old 02-24-2006, 07:14 PM
Omaha_RC_Flyer
Been burning the candle at both ends lately, I'm in the process of designing and kitting a few Professional Series Foamies. I just received my first Depron laser cut kit yesterday. It turned out nice, but I have already made changes to it, to increase the quality and performance of the kit.
Later,
Omaha
Old 04-14-2006, 10:07 PM
Omaha_RC_Flyer
Well I finally made some time to work on the ML Spattern. I still have a little bit of work left, but I see no reason why it will not be finished, and test flown a few times before Spadfest 06. The plug in wings was the hardest part in the whole design. Finally it hit me one day, and this is what I have finshed so far (see attched photos). I will upload a few more photos in the next post.
Photos #1 through #7 Wing Spars with heavy duty package wrapping paper for wing tube sleeves. I made the Spars like an I-beam, with the tube sleeves epoxied in place. They are also tapered and the wings will be swept.
Photo #8 Shows the inside of the fuse where the wing tube is inserted. It is made from CA soaked Fiberglass and epoxied in place.
Photo #9 shows the fuse tube slot.
Photo #10 Wing tube inserted in Fuse slot.
Photo #11 and #12 The wings mocked up, I still haven't glued the spars in place yet.
Later,
Omaha
ID:	445498   Click image for larger version
ID:	445499   Click image for larger version
ID:	445500   Click image for larger version
ID:	445501   Click image for larger version
ID:	445502   Click image for larger version
ID:	445503   Click image for larger version
ID:	445504   Click image for larger version
ID:	445506   Click image for larger version
ID:	445507   Click image for larger version
ID:	445508   Click image for larger version
Old 04-14-2006, 10:18 PM
Omaha_RC_Flyer
Here are a few more pictures
Photos #1 & #2 Spars with wing tube sleeves, made from heavy duty package wrapping paper. I haven't glued the spars in place yet. I had to add the pieces of yardstick on the sides of the spar at the root end to prevent the paper slves from being squeezed out of shape.
Photo #3 Interier view of Landing gear block
Photo #4 Inside view of Firewall
Photo #5 Rudder pull pull guide tubes and Elevator servos
Photo #6 Elevator Servos
Photo #7 Pull Pull Guide tubes
ID:	445516   Click image for larger version
ID:	445517   Click image for larger version
ID:	445518   Click image for larger version
ID:	445519   Click image for larger version
ID:	445520   Click image for larger version
ID:	445521   Click image for larger version
Old 04-14-2006, 10:46 PM
acam37
My Feedback: (16)
acam37's Avatar
Well, when is the maiden video going to be posted?! I have anticipated this for a long time, so lets get busy and finish this sucker. LOL
Old 04-14-2006, 10:50 PM
Omaha_RC_Flyer
Next, I will be finishing up the wings, by adding a root insert with wing bolts and wing alignment dowels. Then I will be moving on to Vacuum form the canopy and Fiberglass the cowl plug. I'll add more photos as I go.
Later,
Omaha
Old 04-15-2006, 03:45 AM
Omaha_RC_Flyer
Here are a few more pictures! I started fiberglassing the cowl also.
Later,
Omaha
ID:	445583   Click image for larger version
ID:	445584   Click image for larger version
ID:	445585   Click image for larger version
ID:	445586   Click image for larger version
ID:	445587   Click image for larger version
Old 04-15-2006, 10:18 AM
grumpE
grumpE's Avatar
Yet again I take a bended knee before the plastic master...............................
TOO DAMN COOL! A YS powered SPAD.
Eric
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
