Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
 spad 3dt for second plane? >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 09-22-2005, 06:01 AM
martno1fan's Avatar
Default spad 3dt for second plane?
hi i was wondering if the 3dt was suitable for a second plane?,ive never flown a 3d plane but im currently flying a trainer and i like the idea of a fun fly type plane that flies easy but that is capable of hovering and such like!!.i have an os 46 la engine in the trainer would this be good enough or would i need more power?,or is there another plane that i could use it in that will hover?.also id like to be able to hand launch the plane too is this possible and whats the best way to do it?.any help would be great guys thanks!!.
Old 09-22-2005, 07:03 AM
exeter_acres's Avatar
Default RE: spad 3dt for second plane?
nope.... not even close....
they are VERY twichy and excpet for hovering and harriers, don't fly all that well...they are fun, but don't fly that well.....
Old 09-22-2005, 08:23 AM
I would agree with exeter acres, my last student went from an avistar to spa3d, not very pretty. I would suggest a DPS for a second plane if you want a spad
Old 09-22-2005, 09:41 AM
martno1fan's Avatar
thanks guys it was worth a try?,i was allready thinking of the dps but where i fly i need something i can hand launch in the winter as the grass is too long and bumpy hows the dps for that?.is there another funfly type of spad i could try?.
Old 09-22-2005, 12:33 PM
You could hand launch the DPS if need be, just jeave the gear off. If you did want to R.O.G., the DPS would be fine. I have a TT Pro 46 on mine, gets off the ground in pretty short order. As far as other fun fly type spads, check out the QHOR, they fly more like "conventional" planes, the "Spazzler" could be another alternative. You really need to learn how to use the rudder for the spa3d
Old 09-22-2005, 01:28 PM
martno1fan's Avatar
cheers for the advice mate !!
Old 09-22-2005, 01:34 PM
I built a DPS with an OS .46 AX... no gear.. hand launch, belly land.....
They are fun, but be careful... it has a glide ratio equal to a set of car keys![:@]
Dead stick with DPS = bad things!
but in its defense... it is darn near indestructable!
Old 09-23-2005, 03:00 AM
martno1fan's Avatar
i like the look of the qhor would an os46la be ok in it?i have one looking for a home!!.also does she hover?,i know the la isnt a powerhouse so maybe it wont with this engine?.maybe i could put it in and see how she flies and keep an eye out for something more powerfull!!.any help is appreciated guys.i supose what im looking for is a funfly that will hover!!.
Old 09-23-2005, 11:55 AM
My Feedback: (19)
Here's a link to a video of a modified Qhor, powered by a Thunder Tiger 42GP.....which is real similar to your 46LA in power and weight. As you will see, your 46LA will work fine.
http://www.spadtothebone.com/videos/mcdddfunflying.wmv
Old 09-23-2005, 12:58 PM
martno1fan's Avatar
cool vid thanks mate now all i gotta do is learn how to hover !!!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
