S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
name of foam type??
Old 06-03-2006, 07:24 PM
jetranger-RCU
Default name of foam type??
Horizon has a hydro the boat is made out of some kind of foam about 1/8 inch thick. It's the one that flys off water. The foam is solid very light and strong. Would make great wings for some park flyers . Any one know what it is called????????
Old 06-03-2006, 09:12 PM
DLSmith2
DLSmith2's Avatar
Default RE: name of foam type??
jetranger-RCU,
I think what you're referring to is called Depron foam. A number of foamie 3D ARFs are made out of it. You can also go to Lowe's or a similar store and get the blue fanfold insulation foam and use it.
Blue skies,
DL
EDIT: Some other possibilities are EPP (Extruded PolyPropylene?) or maybe EPS (Extruded PolyStyrene?).
