Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
 Spad (CC) Edge 540 Maiden Flight... >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 07-14-2008, 03:22 AM
Default Spad (CC) Edge 540 Maiden Flight...
hi,
Here this my new Spad (CC) Edge 540. Just maiden yesterday,
But she needs some changes. 1- Making a new landing gear. 2- Apply to the skewers on elevator and horiz.stab, due fluttering during flight.
Model Spec:
Engine: Installed 2 Cy. 51 magnum engine. (And it was great.)
Fuselage: 116 cm
Wing Span: 121 cm
Airfoil Tickness (at max. point) : 7 cm
Fuselage material : 2 mm coroplast
Wing material: 2 mm coroplast
Control surfaces and Horizontal Stab. : 4 mm coroplast
Radio: 5 standart servo
Flight weigh: 2200 gr.
Check out pictures;
Old 07-14-2008, 03:23 AM
Default RE: Spad (CC) Edge 540 Maiden Flight...
Maiden Flight photos
Old 07-14-2008, 03:24 AM
And first flight video;
http://www.vimeo.com/1333648
would you like to see edge 540 building progress, please click link below;
http://www.pistbasi.com/foto/proje/2...padedge-1.html
Old 07-14-2008, 08:04 AM
draftman1's Avatar
very nice edge!! great good. I had the same fluttering problem on mine. I am gona do a servo for each elevator half next time. that wire between them isnt enough. enjoy the plane, its great
Old 07-14-2008, 08:31 AM
TruBlu02's Avatar
Cool Plane! Instead of the skewers you should try some carbon push rods. I ordered a set yesterday and they are not too expensive. I ordered mine from hobby people for around $7 for two 24" pieces. Should take care of the fluttering problem.
Old 07-14-2008, 11:10 AM
ORIGINAL: TruBlu02
Thanks guys. It looks easy, cheap & great idea. I'll try...
best regards
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
