S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
UK spadders ?
Old 06-26-2003, 10:41 AM
DominicM's Avatar
Default UK spadders ?
Can you tell me where you get your Ali rail and PVC square pipe from ? I'm in London and the South West. And what prices are you paying for white correx 8'x4' sheets. I paid 16 locally which seemed a little rich.
Have been to B&Q and Homebase and no luck. Ali rail is either to narrow for standard servos and all the PVC pipe is round. And I don't want to have to buy micro/mini servos or build a flying drain pipe ! Any help appreciated.
Old 06-26-2003, 11:51 AM
hi,
Try Travis Perkins or other builders merchant such as Jewsons for square drainpipe.
as for the correx its usually called fluted Polypropylene in the UK by sign shops ect. i pay about 7.60 for 2440mm x 1220mm x 4mm..... Cherwell sign supplies are reasonable and deliver Tel 01280 840297
Old 06-26-2003, 11:52 AM
Default where in south west ?
i'm from Gloucestershire area do you fly anywhere near ??????
Old 06-26-2003, 11:59 AM
DominicM's Avatar
Cheers Stedge....hadn't thought of Jewson's.
Old 06-26-2003, 12:03 PM
DominicM's Avatar
I'm down in Hampshire. No one in our club has shown up with a Spad yet only Mugi delta type jobs. I built my first PQHOR. Took all of...ohhhh....2 hours after getting the bits. Will maiden flight this weekend. Got the ali rail from B&Q and found it was too narrow for standard servos. Had to use the only SD200s I had. Got the polyethelene chopping board from Woolworths for 5.99. Got 6 3'x4' mounts out of it. With my Irvine 46 it tends to bend down a little. Should I be concerned with this ?
Gotta start on the 3D QHOR variation tonight, then a GEEBEE, and then a P38 twin, then something with my Laser 150 4C up front.... I got da spad bug good and proper.
Old 06-26-2003, 02:51 PM
www.screwfix.com item nos 34212 and 11834 for square downspout but 15M pack (45 feet) is a little more than you are likely to need at 27.99 ukp. Local builders merchants in Cheshire have or can order it.
Ally U section from B&Q but only in sizes 10 x 10mm 10 x 20mm and 20 x 20mm.
Have you tried supertec mini/std servo, halfway between mini and std size, std torque and std price.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
