S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
4' PCV or fence post
Old 06-26-2003, 04:25 PM
Default 4' PCV or fence post
I bought some 4' fence post from Home Depot and am questioning whether I got the right stuff because it is real heavy.
The stuff I got is white on the outside and gray on the inside. The wall thickness is about 1/8 inch.
Has anybody used this stuff and if not what was the brand name of the stuff you did use.
Old 06-26-2003, 05:02 PM
My Feedback: (21)
Matt Kirsch's Avatar
Right stuff for what, exactly?
If you were looking for gutter pipe, then no, you got the wrong stuff.
"Fence post" != "Gutter pipe"
Old 06-26-2003, 05:15 PM
Good point - were you looking for downspout - or fence post?
If you were looking for downspout - it's not the right stuff.
If you were looking for vinyl fence post - it's the right stuff!
The 4" square stuff that you have is what I used to make the Ultra SPADStick. I used it for front section former (where the firewall screws to), and for an additional former in the rear of the fuselage. By itself it is pretty heavy - but if you use it as formers for a Coroplast fuselage it is awesome!!!
A guy named SpaceGhost made a plane with the fence post stuff - and he reported that it flew very well. Here is the link:
http://www.rccombat.com/forum_2000/t...chTerms=spugly
Old 06-28-2003, 05:07 AM
Yes I was looking for 4' fence post to use in a project similar to your new Spadstick.
I had only planed on using it as formers but it still seamed very heavy.
I have since drilled lots of lightning holes in a piece and it seems a lot lighter.
Old 06-28-2003, 05:14 PM
My Feedback: (10)
Yep its very heavy. I think it weights about 1.25 pounds a foot so its heavy! My big spad came out at 16.25 lbs and it flys great with the 45 homey. I used the post as formers in a coro fuse.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
