Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
HS 81 MG servo problem on PBF >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 06-26-2003, 10:40 PM
Default HS 81 MG servo problem on PBF
On my PBF I can't get the servo to pull the elevons past 1.5 inches, I have lots of throw left on it but it doesn't have the umph I guess....so I'm switching to HS 77 Low profile High torque servos...double the torque......take care of the problem?
Old 06-26-2003, 11:39 PM
Deadeye's Avatar
Try slitting the hinge a little at a time. And make sure the hinges arent binding somewhere. A friend of mine uses micro servos on his 24 X 24 PBF, and they work just fine.
Old 06-27-2003, 12:13 AM
Punch a hole about 1 1/2 from the tip on the hinge linePunch 2 holes 1 1/2 in apart at the centre of the aileron. Punch one more hole at the root of the aileron 1 1/2 in. Slit from the tip hole to the centre hole. same at the root and you got her done.
Old 06-27-2003, 12:36 AM
My Feedback: (19)
Using a 6.0 volt battery might help too.
Old 06-27-2003, 02:27 AM
Flypaper, I took your advise and it works great, unbelievable difference....thanks for your help
Old 06-27-2003, 12:04 PM
Your welcome, Joe. Had the same problem at first. Thank you to Dave, for the concept. Never had so much fun with my clothes on.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
