Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
What servos to use in my spad? >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 06-27-2003, 12:50 AM
Default What servos to use in my spad?
I am building a corospit spad with four channels and have a question regarding my servos.
I already have two servos that have come out of a car but they are Futabas.
The receiver I have is a Hi-tech so what I wanted to do is use the two futaba servos I have but replace the plugs with Hitec plugs. Then I was going to buy two more Hitec servos to use also.
Can anyone see any problems with doing this?
Also do Futaba servos have a different size shaft to Hitec servos as I couldnt seem to fit my hitec control horns on the Futaba servos?
Troy.
Old 06-27-2003, 02:15 AM
Not sure about the horns BUT the Hitec recievers should accept the Futaba plugs not problem unless they are real old plugs, i which case the wireing is ass about as well (i think)
Old 06-27-2003, 03:32 AM
Woddsy,
The plugs look almost the same except they have a small ridge of plastic about 1mm thick down the side of the plugs length. This stops them from plugging into any hitec gear. I suppose I could just file away the plastic ridge but is the wiring the same for Futaba and Hitec??
Old 06-27-2003, 03:34 AM
dickj's Avatar
Cut the key off with an exacto knife and they will work great.
Old 06-27-2003, 05:16 AM
The Hitec RCD3500's and HFD08RD's i use acomodate the little futaba ridge
Old 06-27-2003, 11:22 AM
Default Get small width servos if you can
In case you ever want to build a SPA3D or QHOR, the fatter 0.8" HiTec Servos are very tight going into a 3/4" U-channel.
I ended up cutting the little tab off the Futaba plugs and using two them in my SP3D.
You can see all the Hitec dim spects at www.servocity.com
Old 06-27-2003, 12:40 PM
`3D
And metal gear servos will take a little more of a beating than the plastic ones.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
