S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
what .46?
Old 06-29-2003, 02:28 AM
Hummve
Default what .46?
what .46 should i buy i don't know what is good or bad don't want to spend more than $80 ether.
Old 06-29-2003, 02:32 AM
tileflyer
My Feedback: (9)
Default what .46?
Thunder Tiger ,GMS or Magnum.
Old 06-29-2003, 03:08 AM
rsieminski
Default what .46?
Magnum XLS! I got 5 of them, all are as powerful as the OS equivalent, great carbs, easy to adjust, true ABC!
Old 06-29-2003, 04:28 AM
trroscoe
My Feedback: (39)
Default what .46?
Get the Thunder tiger 46 pro or the GMS 47 both are great engines. The Magnum 46 xls is also a good engine.
Rick
Old 06-29-2003, 07:19 AM
Woodsy
Default what .46?
TT46 or GMS47 for my vote
Old 06-29-2003, 11:36 AM
Crash90
My Feedback: (17)
Default what .46?
tt46BB. my vote
Old 06-29-2003, 02:22 PM
stdun
Default what .46?
Are these motors really as good as the more expensive os46fx?
Old 06-29-2003, 02:59 PM
adrian-RCU
Default what .46?
tt/mag/sc/asp as good as the rest and the price perfect!!
Old 06-29-2003, 05:05 PM
Homebrewer
My Feedback: (8)
Default what .46?
I'd stay away from the GMS .47 since it often won't shut down/quit running when carb is fully closed. I think its an important safety feature to be able to kill and engine especially if something such as a catastrophic failure in flight (tail feathers falling off) occurs.
The TT .46 is a great engine and equal in many ways to the OS .46fx for less $$. The Magnum .46 is also a very good clone of the OS .46.
Old 06-29-2003, 07:13 PM
pinball-RCU
Default what .46?
Even if they were the same price, I'd buy the TT .46 Pro before an OS .46 FX. The reason: The TT survives crashes 100 times better. (And don't get me started on the remote needle valve.) Otherwise, I doubt you could tell them apart in terms of power, ease-of-use, etc.
Old 06-30-2003, 12:59 AM
Captain351
Default what .46?
This problem is easily solved buy coating the Carb hold down bolt with RTV before tightning. I also haven't seen this problem for over a year I believe they have fixed the ploblem.
I have a Tower Hobbies .46 that is the best running engine I have ever had. I believe the only short comming these engines have is with the carborator. I have seen others who have this engine that don't run as well as mine.
Old 06-30-2003, 01:22 AM
thudriver
Default what .46?
Hey guys, give the new Evolution 46 a try. They are prerun and adjusted. I am a newbie but the things just run and run with no fiddling and seem to have good power, I use a 11x 5 on my spad3d. thudriver
Old 06-30-2003, 01:57 AM
Homebrewer
My Feedback: (8)
Default what .46?
Call me cheap but how can a true spadder be recommending a new engine purchase ?
I've had much luck with used Royal .46BB engines purchased from here and auction websites. I've got 3 now and paid on average 35 bucks for each one. They run great and have almost as much power as a TT .46, about 300-400 rpm less but not noticeable otherwise. If you look at the large auction site, you'll see one that is NIB and it probably will be sold for about 50 bucks-which is still cheaper than any other NIB engine.
Andy
BTW, I helped a friend at field break in his GMS .47 2 weeks ago, it wouldn't stop with carb fully closed. Problem still remains and a new engine shouldn't need anything else other than a glow plug and fuel to run good.
Old 06-30-2003, 02:23 AM
Woodsy
Default what .46?
"Problem still remains and a new engine shouldn't need anything else other than a glow plug and fuel to run good."
True BUT give me a $160 GMS over a $250 FX any day, even if the GMS does need to be sealed up, having said that the TT46, TS46 and Force46 are all about the $160 and i've had no problems with them (Aussie $ used)
Old 06-30-2003, 02:31 AM
ChrisSpad
Default what .46?
As an instructor, i'd much prefer someone had a new engine. While i can tune someone else's headaches most of the time, 99% of the time, the new engine has fewer problems, and makes for getting the students more flight time, and less time trying to troubleshoot the engine.
But, there's nothing wrong with used engines, but, i wouldn't recommend them for beginners. If you can tune your own engines, and feel confident in your abiities, then by all means go for it.
Old 06-30-2003, 02:45 AM
thudriver
Default what .46?
I paid $80.00 for my evolution 46 but I think they have gone up a little bit. I bought at LHS , it is distributed by Horizon Hobbies. thudriver
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
