S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
SPAD
Old 06-13-2010, 10:45 PM
Default SPAD
I know that building a spad on your own is supposed to be an easy task and cheap, but I've heard of people that sell assembled SPADs. Does anyone know anything about this? I'm lazy, I'd rather spend my time flying than building.
Old 06-14-2010, 12:34 AM
Moderator
Default RE: SPAD
It's not worth the work to build one and sell it. Not when balsa ARF trainers can be had for under $100 and fly better. And truthfully, they don't save you much money, if any at all. The airframes are cheaper, but radio gear and engines still cost the same. And if you have one crash with a SPAD that you wouldn't have had otherwise you're in the hole.
For cheap and easy, peruse the buy and sell forums here and Craigslist to find good used airplanes.
Old 06-14-2010, 02:20 AM
OzMo's Avatar
Default RE: SPAD
Spads are a lot fun and build easy enough. They can take a bit of rough stuff and keep flying. Build time is much shorter once you get the hang of 'em. SET UP, as said above, is the same as any other plane....always worth doing right.
Old 06-14-2010, 09:15 AM
Default RE: SPAD
I found it: www.spadflyer.com
Old 06-16-2010, 07:42 PM
Default RE: SPAD
Idasam, See also norcalspads.com. He makes a wider variety of arf's.
Old 06-17-2010, 06:25 AM
Clean's Avatar
Default RE: SPAD
Try these, I know the dude personally and have seen his products.
http://midcalspads.com/General.html
Old 06-17-2010, 07:11 AM
huck1199's Avatar
Default RE: SPAD
The 40" fuse and 48" wing from spadflyer is a nice flying plane.  Dont' get the shorter fuse; it is not as easy to control of balance.
Old 06-17-2010, 04:52 PM
carlosponti's Avatar
Default RE: SPAD
i have the short wing kit from spadflyer its a fun airplane and you can put a supertiger 51 on it for cheap. I use a 12.25x3.75 on one of the old ST 45 italian made engines. on the supertiger 51 its a screamer.
Old 06-18-2010, 03:04 AM
Default RE: SPAD
ORIGINAL: Idasam
Ed Sorrels, who runs Spadflyer, is a great guy. The plane is a good flyer, and very tough. The other day, it was a bit too windy to fly; 20 MPH, with gusts well above that. With several of us standing around the field, hoping the wind would die down, I was the only one to put a plane in the air. I made four flights with my Spadflyer, and one with my grandson's. It's nice knowing you can take a few risks without winding up having to spend several hours repairing your plane. Some of my landings weren't very pretty, but no damage. I wouldn't have put a balsa plane in the air under those conditions. Thanks; Ernie P.
Old 06-20-2010, 10:25 AM
Default RE: SPAD
I planted another Balsa bird today. if it was a SPAD I could prob repair her...not enough cable ties for this one....back to the SPAD Bipe.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
