S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
SPAD Pylon Racing!!
Old 06-21-2010, 12:19 PM
My Feedback: (36)
Default SPAD Pylon Racing!!
This Sunday, June 27th 2010, Boise Area Remote Kontrol Society (BARKS) in Boise , Idaho is hosting a SPAD Pylon Race. The Airplane is the Das Plas stick, with sport motors from .45-.55.
Here are some pic's from Fathers day SPAD Gathering.
ID:	1456390   Click image for larger version
Old 06-21-2010, 02:37 PM
My Feedback: (36)
Default RE: SPAD Pylon Racing!!
To answer the question: The engine and setup of choice has become the Magnum .52 turning a master airscrew 11x7.5 on 15% Omega fuel. Makes for speeds in the 90-100MPH range.
The rules are:
PILOT:
This class is intended to introduce pylon racing to experienced pilots wanting to race. It is designed to be fun, and challenge pilots skill, not his or her pocket book.
AIRCRAFT:
The aircraft must be of a “Das Plas Stick” build according to the free plans on www.spadtothebone.com specifying .40 size or larger engines. ** See Note
The following modifications may be made:
1. The wing may be bolted on, or rubber bands as per the plans.
2. The Wing may be made from straight 4mm Coroplast in lieu of 4/2mm combo used in the plans.
3. The shape of the vertical and horizontal tail may be changed, provided stock dimensions are maintained. The vertical fin may be mounted in the center of the fuselage for aesthetics.
4. Repair of previous crash damage is allowed provided the structure integrity is maintained, i.e. duct tape to cover minor slices/dings in wing.
REQUIRED EQUIPMENT:
1. The fuel tank must be an 8 ounce of any brand. Engine must use muffler pressure to pressurize fuel tank only.
2. Three wheels at least as large as the original wheels called for in the plans. No tire modification is allowed.
3. Any sport, non-pylon specific, ball bearing .45-.55 size two cycle engines may be used. Example engines: Thunder Tiger 46, O.S 46-55 AX/FX/FSR, Super Tiger .45-.51, Magnum .46-.52. Brands like Rossi, Jett and Nelson are not allowed. A stock muffler must be attached, no mousse can or mini/tuned pipes.
4. Propeller to suit engine must be used for the race; Size range must be from 10” to 11” in diameter, pitch to suit your taste. Engine will not exceed 14,000 RPM’s on the ground measured by a tachometer.
5. Spinner or AMA safety nut should be installed.
6. Be able to stop the engine by radio.
7. Have separate controls of all three axes and engine of the aircraft.
RACING:
1. The racing will be conducted on the same style of course, and generally in the same manner as Two Pylon Club Racing recognized by the AMA.
2. The start of each race will be a fixed start or air start. The CD (Contest Director) will advise when to start your engines, and what style of start to expect. You will have 2 minutes to get your plane started and in the air. The CD will then start a 1 minute count down. At the count of zero, the announcement “you have a Race” will be made, you must behind the start finish line. Any plane that is over the start finish line will be down 1 lap. In the event of all planes crossing the start finish before the count of “0” the race will be re started.
3. If a pylon is cut, the pilot will be down 1 lap. If the same pilot cuts a pylon twice, he will be given 0 points for that race and receive a DQ.
4. You may use any fuel of your choice from FAI (no Nitro) up to 15%. (No fuel will be supplied)
5. There will be 3-4 pilots per heat. Each race will be 10 laps or 3 minutes in length (CD’s discretion), and a minimum of 3 heat races, followed by a main event race with the top 4 highest scoring pilots competing from the heat races.
6. Scores: 3 points for 1st. 2 points for 2nd. 1 point for 3rd. 0 points for 4th, DQ & DNS. (CD determines number of tickets to hand out similar to fun-fly scores)
7. Each pilot should have a holder/caller, and a safety observer will be present to call a “knock it off” if an emergency or out of control situation exist. Should the safety observer call a “knock it off”, pilots are expected to immediately leave the area of the race course and climb to safe altitude and await instructions to land.
**Note: ANY AIRCRAFT NOT COMPLYING WITH ABOVE REQUIREMENTS MAY BE ALLOWED TO COMPETE AT THE DISCRETION OF THE CONTEST DIRECTOR, IF HE DETERMINES THAT THE NON-COMPLYING AIRCRAFT HAS NO SPEED ADVANTAGE OVER COMPLYING AIRCRAFT.
Old 06-24-2010, 08:45 PM
Looks like you guys are having too much fun. We are racing spads here in Central, Ca. we are using spad combat planes with 42" wing spans and the engine of choice is the OS25SF.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
