Go Back  RCU Forums > RC Airplanes > S.P.A.D. Aircraft - Coroplast design
 what size servo for DRACO >
S.P.A.D. Aircraft - Coroplast design Discuss the growing area of S.P.A.D.S. (Simple Plastic Airplane Designs). Coroplast type aircraft, pizza box planes, etc..
Old 07-26-2010, 06:25 PM
Default what size servo for DRACO
I am building a 54" DRACO. Will Hitec HS82 servos be a good choice, or should I go with a full size stronger servo?
Old 07-26-2010, 06:56 PM
draftman1's Avatar
Default RE: what size servo for DRACO
that size will work fine, just make sure you get the metal gear version, the 82MG's
by the way, have you seen this http://www.youtube.com/watch?v=0bCIeJfdApI
Old 07-26-2010, 07:11 PM
Thanks I wanted to use smaller servos so that I could bury them in the wing for a clean look. I have watched the video and will watch again. I am just making the spar using 1/4 popular. the taper cuts are the most difficult part of the build, but I am attempting to use the taper jig on my table saw. a band saw would be nice, but I dont have one yet. I'll post some pics as the build is in progress. I have a Evolution 36 for power. wing will be all 2 mil with a 3/16" carbon rod to strengthen the leading edge.
this wing is built with a flat bottom - correct?
Old 07-27-2010, 06:47 AM
draftman1's Avatar
your definatly on the right track, the wing is semetrical, when you fold it over, it raises the leading edge uop just where you want it. I just free hand cut the tapers on the table saw and then sand them. good luck and have fun!
Old 08-01-2010, 11:32 PM
jib
I've tapered the spar with a belt sander.
Jack
Old 08-02-2010, 09:03 AM
Villa's Avatar
Hi wjbender
As I mention in my post of 7-28-10, I mount my standard size servos completely inside the wing, with only a portion of the servo arm protruding. I do the same for the receiver, and have also mounted the battery inside the wing. I have been doing it for more than 5 years with no problems that I can recall. Let me know if you have any questions.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
