Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Scale Racing
Reload this Page >
8th Scale Aviation's, "CzechMate" Short-kit, Group build
Scale Racing Discuss all aspects of semi-scale pylon racing.
Old 06-17-2016, 09:51 PM
  #251
Iron Dog
Iron Dog's Avatar
Just after we broke for lunch, Eric decided he wanted to try to fly his mini Foamie Warbird around my pastures. I warned him that I had flown my FlyZone Corsair and found it difficult to avoid my many trees. (That’s a nice way of saying, “I crashed into a really tall pine tree, and broke my plane when it fell and impacted the ground, shortly after I moved into this property a couple years ago.”)
Un-phased, Eric decided, “I’m sure I can avoid them!”
Anyone care to guess how that worked out for him? . . .
“Ummm . . . Ollie . . . Now what do I do?!”
Old 06-17-2016, 10:01 PM
  #252
Iron Dog
Iron Dog's Avatar
(He never made it to either of my open pastures.)
This is Eric going net-fishing for a mini-foamie P-47 Warhawk out of another one of my pine trees.
ID:	2168443   Click image for larger version
ID:	2168444   Click image for larger version
Old 06-17-2016, 10:16 PM
  #253
Iron Dog
Iron Dog's Avatar
After lunch -- and Eric's short flight, we installed the pushrod tubes.
Tim includes the lasercut pushrod keepers, pictured below. Place a pair of these keepers on each of the tubes first. Run the tubes in a straight line, between the servo output arm and the elevator and rudder control horns. Glue the keepers to whichever part of the formers allow a good solid glue-bond, while equally spacing this reinforcement to keep the tube from flexing while under load and that will also keep the tubes straight.
ID:	2168446   Click image for larger version
Old 06-20-2016, 05:12 AM
  #254
FlyerInOKC
FlyerInOKC's Avatar
An hour or two and a D9 can fix that problem! ;-)
I like the way the pushrods went in!
Mike
Old 12-06-2016, 10:12 PM
  #255
Iron Dog
Iron Dog's Avatar
Alright . . . Race season is over. So, time to get back to posting the progress of our build, thus far, in order to get you all caught-up. We haven't been able to get together very regularly these last few months to continue the build., but were able to do so a couple times in the last month. Now, let's see how well I can remember where we were -- and exactly what we did -- beginning 7 months ago:
After the pushrods were installed, the wing mounting block came next.
First, Tim set the wing into position on the wing saddle. He marked the position of the trailing edge of the wing onto the saddle doubler. Another mark was drawn one inch in front of the initial mark. The width of the fuse was measured between these marks, and a 1" wide piece of plywood was cut (ever-so-slightly oversized), and then carefully sanded to-size, to fit snugly between. If you look carefully at the pictures, you will notice a 1/2" balsa block was cut and sanded to the same width and glued to the center of the plywood wing mounting block.
Tim glued this 2-piece assembly ito position, about 1/16" below the edges of the saddle doubler.
Tri-stock pieces were then glued, as shown, to more carefully secure and reinforce the wing mount block.
ID:	2192512   Click image for larger version
ID:	2192513   Click image for larger version
ID:	2192514   Click image for larger version
Old 12-06-2016, 10:22 PM
  #256
Iron Dog
Iron Dog's Avatar
We then used some of our left-over bamboo skewers to further reinforce the integrity of the bond of the wing mounting block. One hole was drilled into the side of the wing saddle doubler and into the 1/4" ply block, and another hole drilled into the balsa block. (This was completed on both sides.) Epoxy was then applied, and the four skewer lengths were inseted.
ID:	2192516   Click image for larger version
ID:	2192517   Click image for larger version
Old 12-06-2016, 10:29 PM
  #257
Iron Dog
Iron Dog's Avatar
Eric follows suit:
(Quick note: I was busy taking pictures and wasn't watching carefully, to notice he was using thin CA, instead. He was unable to insert the skewer far enough, or at all, into the blocks before the glue set to have a solid dowel joint. We had to drill-out the skewer, then, try again. Do not use thin CA; if you want to risk thick CA, then you need to work very fast; using epoxy, for this purpose, is recommended.)
Wipe away excess; and when dry, cut the skewers nearly flush to the side of the wing saddle doubler. Sand the dowels/skewers flush.
ID:	2192519   Click image for larger version
ID:	2192520   Click image for larger version
Old 12-06-2016, 10:45 PM
  #258
Iron Dog
Iron Dog's Avatar
In preparation for fiberglassing the center section of the wing, wood filler was applied around the seam of the panels, and allowed to dry.
While drying, we installed the throttle pushrod to align with both the throttle servo and the position of the carb's control arm of a YS 70 engine. (None of us have actually decided if we are installing a YS 70 or the newer 80, yet.) Eric's wing and fuse are shown in the pictures, below.
ID:	2192522   Click image for larger version
ID:	2192523   Click image for larger version
ID:	2192524   Click image for larger version
Old 12-06-2016, 10:52 PM
  #259
Iron Dog
Iron Dog's Avatar
Our Tettra 350 cc (12 oz.) tanks were prepared. Holes were cut through the firewall to align with the nipples of the regulator.
ID:	2192526   Click image for larger version
ID:	2192527   Click image for larger version
ID:	2192528   Click image for larger version
Old 12-06-2016, 10:57 PM
  #260
Iron Dog
Iron Dog's Avatar
The filler has dried, and the center section of the wing was sanded. A tack cloth removed the dust, and both the top and the bottom of the center section were fiberglassed, using heavy, 3" wide reinforcement tape and Z-Poxy finishing resin.
ID:	2192530   Click image for larger version
Old 12-07-2016, 07:16 AM
  #261
FlyerInOKC
FlyerInOKC's Avatar
You left out the part where one of the builders glues himself to the airplane or was that earlier in the build? ;-)
Old 12-08-2016, 07:47 AM
  #262
Pylonracr
Pylonracr's Avatar
Or glues the plane to the bench. We all do that right??? Wait, is it just me???
Old 12-08-2016, 08:00 AM
  #263
FlyerInOKC
FlyerInOKC's Avatar
Sigh, I think it is as common as gluing oneself to the airplane.
Old 12-08-2016, 05:34 PM
  #264
Tommy_Gun
Tommy_Gun's Avatar
Open the fuel line holes up a bit larger and use electrical heat shrink to protect the lines going thru the firewall.
Or don't.
Old 12-08-2016, 07:09 PM
  #265
Iron Dog
Iron Dog's Avatar
Or don't.
After my experience at the NATS, that sounds like advice well worth taking!
My flight to Indianapolis was delayed, and by the time I finally arrived at AMA HQ, I only had enough sunlight left the day for one test flight. That flight was cut short when my P-39 developed a leak in the fuel system and dead-sticked. I landed safely, and replaced the entire fuel system just before dark. Went up early in the morning, to finally try to finally get some timed laps on the course, and even with all new equipment and lines, dead-sticked again. This time, was too low and on wrong end of runway for such ridiculously strong winds. Came up a couple feet short, and ripped the wing mounting blocks out of the fuse. I was forced to compete with my back-up, which I had just maidened. Needless to say, the competition didn't go so well, for me.
Both times, I found a pin-hole in a fuel line. Better to eliminate the risk of similar issues, when so easy to do so. With the P-39, I think it was the lines finding a fiberglass "needle." But have experienced pin-holes in the lines, where they come into contact with the firewall, a number of times over the last 20+ years, too. So, will take your suggestion, as well as wrap the rest of the length of the lines (as much as practical), to insulate them from friction for the rest of their run to the fuel tank.
In competition, reliability and consistency is critical. Good suggestion, Tommy.
Old 12-10-2016, 11:34 AM
  #266
tdstaf
tdstaf's Avatar
What do you mean left over? I think we have enough left over for 50 airplanes.
Old 12-10-2016, 11:36 AM
  #267
tdstaf
tdstaf's Avatar
Don't worry I'm pretty sure it happened many times....
Old 12-10-2016, 11:37 AM
  #268
tdstaf
tdstaf's Avatar
This one too...
Old 12-11-2016, 09:55 PM
  #269
Iron Dog
Iron Dog's Avatar
Time to make cowl molds!
In order to show Tim and Eric my methods for making molds, we are making them for both the CzechMate and Tim's new Rare Bear kit. That way, they can each do one. Simultaneosly, I am demonstrating by making a third -- a P-40 mold for my buddy Sergio. All three will be 2-part molds.
Pictures of the CzechMate and Rare Bear plugs, with the parting surfaces mounted; and, after all was waxed and PVA (thus the green tint) applied.
ID:	2193187   Click image for larger version
ID:	2193188   Click image for larger version
Old 12-11-2016, 10:05 PM
  #270
Iron Dog
Iron Dog's Avatar
The gaps between each plug and parting surface were filled with microballoons and resin. The following week, after curing-out, the whole assembly was sprayed with PVA again, then the tooling layer got "painted-on." Tim took Rare Bear, and Eric handles the duties on CzechMate:
ID:	2193190   Click image for larger version
Old 12-11-2016, 10:10 PM
  #271
Iron Dog
Iron Dog's Avatar
Radiusing the corners so the fiberglass cloth will drape appropriately without air gaps:
ID:	2193192   Click image for larger version
ID:	2193193   Click image for larger version
Old 12-11-2016, 10:17 PM
  #272
Iron Dog
Iron Dog's Avatar
November 6th, and the layers of cloth have been applied to the first half of each plug and parting surface:
Old 12-11-2016, 10:32 PM
  #273
Iron Dog
Iron Dog's Avatar
"Rinse . . . Lather . . . Repeat"
Repeating the process for the 2nd half of the mold. The parting surface was removed, and the flange of the first half serves as the parting surface, now. It was "keyed" with a Dremel and a spherical-shaped cutting bit, so that the 2nd half aligns and "locks" into place with the first.
Here, I am having Eric and Tim each cut their own chopped fiberglass, so they can get the "full" experience (instead of me prepping everything in-advance). Afterwards, the other ingredients were mixed in, and the initial layer was applied -- just as before.
ID:	2193196   Click image for larger version
Old 12-11-2016, 10:37 PM
  #274
Iron Dog
Iron Dog's Avatar
December 3rd, and picture shows both molds after the cloth was applied to the second half of each:
Old 01-14-2017, 08:41 PM
  #275
Iron Dog
Iron Dog's Avatar
Mold halves popped-off of both the CzechMate and the RareBear plugs; then cleaned-up.
ID:	2196800   Click image for larger version
ID:	2196801   Click image for larger version
ID:	2196802   Click image for larger version
