Go Back  RCU Forums > RC Helicopters > Scale RC Helicopters
 Hirobo Bell 222 build & painting project >
Scale RC Helicopters Discuss scale helis, and modifications to pod and boom helis that make them scale.
Old 07-19-2007, 09:02 AM
Default RE: Hirobo Bell 222 build & painting project
Christmas lights comes on a little bit earlier this year!
ID:	726096   Click image for larger version
ID:	726097   Click image for larger version
ID:	726098   Click image for larger version
ID:	726099   Click image for larger version
ID:	726100   Click image for larger version
Old 07-19-2007, 09:13 AM
Lighting system will be done like this Bell Long Ranger.
ID:	726102   Click image for larger version
Old 07-20-2007, 10:50 AM
ArrowNaughtic's Avatar
So Impressive! TY for all the detailed pics and steps you took. I will be checking on this thread often. The amount of time involved must be huge. I can't wait to see the end result.
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Old 07-23-2007, 10:22 PM
Thanks ArrowNaughtic,
Yes the amount of time needed is huge, plus i need to plan in advance what needs to be done next, my mind will go crazy sometimes! LOL! Will post when the build is more substantial, don't want to post every other day, that means i'm not spending enough time building it but logging/surfing on the forum! LOL!
I'm fibreglassing the tail as i typed and finishing soon, then comes the horizontal stabs, that whole group is all balsa/ply combination too! Headache! LOL!
Cheers!
Old 07-28-2007, 10:27 AM
Horizontal stab came as a piece of balsa, lots of sanding and shaping involved. After sanding/shaping to the right profile, it's fibreglassed and left to dry overnight, same goes with the hor. stab winglets.
ID:	731250   Click image for larger version
ID:	731251   Click image for larger version
ID:	731252   Click image for larger version
ID:	731253   Click image for larger version
ID:	731254   Click image for larger version
ID:	731255   Click image for larger version
Old 07-28-2007, 10:32 AM
  #31
Reinforcement plate for vertical stab have to be scratch-made from the leftover ply veneer, not a very good design, it should have come factory-cut! Grrrrrrr!
I've replaced these 3 screws with stainless steel half-round machine screws, looks better than the stock cap screw heads.
ID:	731257   Click image for larger version
ID:	731258   Click image for larger version
ID:	731259   Click image for larger version
ID:	731260   Click image for larger version
ID:	731261   Click image for larger version
Old 07-28-2007, 10:37 AM
  #32
All ventilation holes epoxied with nettings.
ID:	731264   Click image for larger version
ID:	731265   Click image for larger version
ID:	731266   Click image for larger version
ID:	731267   Click image for larger version
ID:	731268   Click image for larger version
ID:	731269   Click image for larger version
ID:	731270   Click image for larger version
Old 07-28-2007, 10:39 AM
  #33
I got so excited i put it together just to see how it looked, she is starting to look like a nice sexy heli!!!
ID:	731274   Click image for larger version
ID:	731275   Click image for larger version
ID:	731276   Click image for larger version
Old 07-28-2007, 10:43 AM
  #34
Marking out and hor. stab hole by drawing out the profile from the stab. Cut the slot off, super-impose on the boom and mark out the profile, dremel it carefully, bit by bit, must not over-dremel and end up with a larger hole! Patience is paramount.
ID:	731278   Click image for larger version
ID:	731279   Click image for larger version
ID:	731280   Click image for larger version
ID:	731281   Click image for larger version
ID:	731282   Click image for larger version
ID:	731283   Click image for larger version
ID:	731284   Click image for larger version
Old 07-28-2007, 10:47 AM
  #35
Top of stab was epoxied first, using a bottle to keep the stab level. After this was done, flip the heli fuse upside down and epoxy the bottom part of stab.
ID:	731290   Click image for larger version
Old 07-28-2007, 10:58 AM
  #36
I will use my last finger to run thru the corner, that way it produces a very nice fillet all along the joint line. Tissue soaked with a bit of thinner is then used to run thru that fillet gently. The end result is very good and i'm happy with it.
ID:	731303   Click image for larger version
ID:	731304   Click image for larger version
ID:	731305   Click image for larger version
ID:	731306   Click image for larger version
ID:	731307   Click image for larger version
ID:	731308   Click image for larger version
ID:	731309   Click image for larger version
Old 07-28-2007, 11:02 AM
  #37
Left and right winglets are next, epoxied into place, using some small weights to counter-balance it during drying.
Tail group finally done. On with the retracts and lightings...
ID:	731314   Click image for larger version
ID:	731315   Click image for larger version
ID:	731316   Click image for larger version
ID:	731317   Click image for larger version
ID:	731318   Click image for larger version
ID:	731319   Click image for larger version
Old 07-29-2007, 09:31 PM
  #38
mechplas's Avatar
Wow....this is really a lot of work!!!. Thank goodness you have the skill and patience!
Fine piece of work man!
Old 07-29-2007, 11:00 PM
  #39
Thanks Mechplas
Old 08-01-2007, 02:00 AM
  #40
That is really coming along. Love the finger trick also, I am a painter by trade and that is one sweet joint you ended up with. that really is starting to take on some very nice lines. Good job!
Old 08-01-2007, 09:05 PM
  #41
Thank You ArrowNaughtic!
Right now i'm doing up the 3 mechanical retracts, they are linked to one another with 2mm rods and ball links, quite good quality and very little free-play, but some bolts/nylon nuts were so hard to install in some god-forsaken places i nearly resorted to getting my kid to put it in for me because my fingers were too big, well fat actually! LOL! But luckily i managed to put them in after a few tries Just some minus points for this Hirobo kit. [sm=spinnyeyes.gif]
I will take some pictures and highlight some of the good points as well as the bad points of this kit.
Next will be to position the micro switch and the LED lighting system, Navigation lights, anti-collision light, landing lights.
Will post again when more is done, cheers!
Old 08-09-2007, 08:11 PM
  #42
Sorry for late update, have finished with the retracts.
ID:	739069   Click image for larger version
ID:	739070   Click image for larger version
ID:	739071   Click image for larger version
ID:	739072   Click image for larger version
ID:	739073   Click image for larger version
ID:	739074   Click image for larger version
ID:	739075   Click image for larger version
ID:	739077   Click image for larger version
Old 08-09-2007, 08:20 PM
  #43
Micro-switch position located and trial-fitted. When the retracts goes up during hover, the landing lights goes off and vice-versa. Wll be installing 2 ultra-bright white lights on both retract pods.
ID:	739083   Click image for larger version
Old 08-09-2007, 08:24 PM
  #44
Instrument panel/seats done up, 2nd and 3rd pictures shows some dremelling required to clear the ball-link for the front retracts, oops, no choice.
ID:	739092   Click image for larger version
ID:	739093   Click image for larger version
ID:	739094   Click image for larger version
ID:	739095   Click image for larger version
ID:	739096   Click image for larger version
ID:	739097   Click image for larger version
ID:	739098   Click image for larger version
Old 08-09-2007, 08:32 PM
  #45
30 Ply blocks added for lower fuse, as per Hirobo manual instructions! [sm=spinnyeyes.gif]
ID:	739104   Click image for larger version
ID:	739105   Click image for larger version
Old 08-09-2007, 08:38 PM
  #46
All 1.8mm diameter holes drilled.
ID:	739112   Click image for larger version
ID:	739113   Click image for larger version
Old 08-09-2007, 08:41 PM
  #47
Front and back retract holes dremeled and hand-filed.
ID:	739115   Click image for larger version
ID:	739116   Click image for larger version
ID:	739117   Click image for larger version
ID:	739118   Click image for larger version
Old 08-09-2007, 08:52 PM
  #48
This is how she looks at the moment, there's still quite a fair bit to go ....i.e.
1. Navigation LED lights fitting
2. Landing lights fitting at the 2 pods
3. Wiring/soldering, voltage step-down with capacitors before wiring to LEDs
4. Sanding down whole fuse
5. Drowning!!![sm=drowning.gif] (Haha, just kidding!)
6. Primer painting
7. Final Painting
ID:	739130   Click image for larger version
ID:	739131   Click image for larger version
ID:	739132   Click image for larger version
ID:	739133   Click image for larger version
ID:	739134   Click image for larger version
ID:	739135   Click image for larger version
ID:	739136   Click image for larger version
ID:	739138   Click image for larger version
ID:	739139   Click image for larger version
Old 08-09-2007, 09:53 PM
  #49
Awesome!
Old 08-11-2007, 12:08 PM
  #50
Thanks TEX
Ok, the LED lights were finally done today, there is a short video of the lighting system after this few posts.
I bought these indicating lights from the local electrical hardware shop, these lights are for control panels. Cut them in half, just retain the top half for use. They are then tested with 3 volts supply.
ID:	739961   Click image for larger version
ID:	739962   Click image for larger version
ID:	739963   Click image for larger version
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
