Go Back  RCU Forums > RC Helicopters > Scale RC Helicopters
 Hirobo Bell 222 build & painting project >
Scale RC Helicopters Discuss scale helis, and modifications to pod and boom helis that make them scale.
Old 08-11-2007, 12:11 PM
  #51
Default RE: Hirobo Bell 222 build & painting project
Navigation lights done, since i'm tapping the power supply from the flight pack of 4.8v, i use capacitors for each LED, to step down from 4.8v to 3v. Each LED can be connected/disconnected individually.
ID:	739965   Click image for larger version
ID:	739966   Click image for larger version
ID:	739967   Click image for larger version
Old 08-11-2007, 12:12 PM
  #52
Lumeon ultra-bright lights were used for the landing lights.
ID:	739969   Click image for larger version
ID:	739970   Click image for larger version
Old 08-11-2007, 12:16 PM
  #53
For blinker light on top of heli, i used a larger-sized top, mix 5-min epoxy, drip it inside, insert the LED, voila...
ID:	739973   Click image for larger version
ID:	739974   Click image for larger version
ID:	739975   Click image for larger version
ID:	739976   Click image for larger version
ID:	739977   Click image for larger version
Old 08-11-2007, 12:23 PM
  #54
She now lights up like a Christmas tree! ... and would look really cool flying it near sundown
The LED lighting system video link is below:
http://www.rcuvideos.com/item/R9Z2H5WMGR5T6HG1
ID:	739984   Click image for larger version
ID:	739985   Click image for larger version
ID:	739986   Click image for larger version
ID:	739987   Click image for larger version
ID:	739988   Click image for larger version
ID:	739989   Click image for larger version
ID:	739990   Click image for larger version
ID:	739992   Click image for larger version
ID:	739993   Click image for larger version
ID:	739994   Click image for larger version
Old 08-11-2007, 05:51 PM
  #55
really cool job there, that looks sweet!
Old 08-12-2007, 11:40 AM
  #56
What is your paint scheme?
Old 08-12-2007, 07:52 PM
  #57
Thanks Blade_Killer!
This one Tex, but in metallic graphite color with gold trimmings. I'll be using automotive acrylic paints and 2K clearcoat for final.
I will be removing all of the LEDs/mechancis and then sand down the whole fuse, in preparation for first primer coat. Cheers!
Old 08-12-2007, 08:29 PM
  #58
You have a lot of patience.....
Old 08-12-2007, 08:44 PM
  #59
Thanks TEX, my good friend always says this to me ... "Patience is a Virtue"
Old 08-12-2007, 09:45 PM
  #60
ArrowNaughtic's Avatar
Steven,
I just love how far that has come along and I am really impressed by the micro switch activated by the retracts! That is really a masterpiece and thanks for sharing it with all of us. Nice vid of the retracts in action also. Your project is really starting to all come together now. the Cobra is looking good too!
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Old 08-12-2007, 10:16 PM
  #61
mechplas's Avatar
Christmas here already?!!! Nice work...... a lot of hardwork!!!!. This says a lot about your attitude towards R/C hobby. Keep it up my friend!!! [8D]
Old 08-12-2007, 11:02 PM
  #62
alfa13's Avatar
[sm=49_49.gif] hi RAJOO....FOLOWING THIS THREAD?......THANKS STEVEN....I GUESS POLO WILL BE BRIGHTER WHEN THIS HELI IS COMPLETED....
Old 08-12-2007, 11:42 PM
  #63
Hi Alpha13, you are welcome! I'm enjoying building your heli, cukup cheras? (Bright enough?)
Old 08-12-2007, 11:46 PM
  #64
Thank you Mechplas
Old 08-13-2007, 12:06 AM
  #65
mechplas's Avatar
Yes, Alpha13, how can I not follow this thread. Too much valuable tips and tricks....
I have to respect the builder of the heli and the owner of the heli, both embarked on a common mission...... to launch a beautiful heli for all to see and enjoy.
Old 08-13-2007, 06:19 AM
  #66
alfa13's Avatar
COMLPIMENTS SHOULD GO THE THE BUILDER........
Old 08-13-2007, 08:27 AM
  #67
There's a Cobra thread?
What is the link?
Old 08-13-2007, 08:46 AM
  #68
Tex,
The cobra thread is also on the same "Scale RC Helicopters" topic section, it's just a paintjob, not a build thread.
Old 08-19-2007, 07:44 AM
  #69
ORIGINAL: ArrowNaughtic
Steven,
Thank You ArrowNaughtic,
I have tidied up all the wires on the mechanics, and also the wire-driven tail rotor is really easy to install and dismantle. Unlock the front end, pull back the tail rotor, twist it up to about 80 degrees, it will then clear the 3 machine screws at the tail and the whole thing pulls out with ease.
ID:	744999   Click image for larger version
ID:	745000   Click image for larger version
ID:	745001   Click image for larger version
ID:	745002   Click image for larger version
ID:	745003   Click image for larger version
ID:	745004   Click image for larger version
ID:	745005   Click image for larger version
ID:	745007   Click image for larger version
ID:	745008   Click image for larger version
Old 08-19-2007, 07:48 AM
  #70
On/Off switch location next to right middle window, Glow Driver location also situated at this window, for ease of fueling/re-fueling and starting operations.
ID:	745010   Click image for larger version
ID:	745011   Click image for larger version
ID:	745012   Click image for larger version
ID:	745013   Click image for larger version
ID:	745014   Click image for larger version
ID:	745015   Click image for larger version
Old 08-19-2007, 07:52 AM
  #71
Masking done prior to primer painting.
2K Premier Primer Grey SU-5116 used, mixed 4:1 ratio with slow hardener SH-3400 and then thinned down with paint thinner again, took about 2 hours to dry.
ID:	745017   Click image for larger version
ID:	745018   Click image for larger version
ID:	745019   Click image for larger version
ID:	745020   Click image for larger version
ID:	745021   Click image for larger version
ID:	745022   Click image for larger version
Old 08-19-2007, 08:02 AM
  #72
Primer painting went on smoothly, hung to dry for 2 hours, last picture shows pit holes from Hirobo factory, will have to putty it and sand down again another day. After primer painting, i will have to look over the whole fuse carefully, to look out for inperfections and dents, and once all holes are covered up, sanded down, it will be time to shoot the actual colors
ID:	745024   Click image for larger version
ID:	745025   Click image for larger version
ID:	745026   Click image for larger version
ID:	745027   Click image for larger version
ID:	745028   Click image for larger version
ID:	745029   Click image for larger version
ID:	745030   Click image for larger version
ID:	745032   Click image for larger version
ID:	745033   Click image for larger version
ID:	745034   Click image for larger version
Old 08-21-2007, 10:12 AM
  #73
Phew! The whole fuse sanded down and cleaned up. Now is time to make some antennas!
1.5mm carbon rods and discarded plastic clevises from ARFs were used. Sharp penknife was used to slice at an angle on the clevis. Carbon rod inserted and CA'd in place as shown. 1.5mm drilled thru to fuselage and antenna inserted temporarily.
Tail antenna was created with 1/32" birch plywood, 2 pcs CA'd together and hand-sanded down to shape, a tiny hole was then dremeled on the back end of the tail (bottom) for this antenna.
All antennas will be put aside to be painted later, and after the fuselage is painted then these will be glued on with epoxy.
ID:	746316   Click image for larger version
ID:	746317   Click image for larger version
ID:	746318   Click image for larger version
ID:	746319   Click image for larger version
ID:	746320   Click image for larger version
ID:	746321   Click image for larger version
ID:	746322   Click image for larger version
ID:	746324   Click image for larger version
ID:	746325   Click image for larger version
ID:	746326   Click image for larger version
Old 08-21-2007, 10:15 AM
  #74
Door handles were also glued in, here's how she looked at the moment, will start to shoot some paint next couple of nights.
ID:	746328   Click image for larger version
ID:	746329   Click image for larger version
ID:	746330   Click image for larger version
ID:	746331   Click image for larger version
ID:	746332   Click image for larger version
ID:	746333   Click image for larger version
ID:	746334   Click image for larger version
Old 08-22-2007, 01:30 PM
  #75
Wow....even scale windshield wipers! Amazing detail and it looks really good. One question.....did you spray all that in the house with your cup gun? I have a nice little HVLP setup that I use for finishing doors and spraying laquer. It really does a good job for finish and is comparable to automotive finish when I am done. Usually I put about 3 coats of clear over my finished work. Sanding or steel wool between coats with a good wipedown with tack cloth or a thinner soaked rag then wiped dry with a clean one. If you can't tell, the painting part is one of the more exciting parts of any build for me. I love how something is transformed when product is applied properly and care is taken to ensure a quality finish. Thank you Steven for sharing such a wonderful project and in such detail. the tips and trick all through this thread are invaluable also!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
