Schumacher Racing Discuss all Schumacher Racing products here!
fusion wont start
Old 06-10-2007, 04:40 PM
Default fusion wont start
Hi rc world,
ive got a fusion 21 with a e-start and im having a few probs could any1 help.
when i try and turn the e start it just locks up and the drill forces my hand round, ive used a piar of grips to try and turn it (gently) and
it turns. ive only used the car once but it was wet and the wheels kept spinning could i have blown the engine up.
or is it just the e start.
cheers aaron
Old 06-10-2007, 04:45 PM
Default RE: fusion wont start
ANY 1
Old 06-10-2007, 04:49 PM
Slammed's Avatar
well to me it sounds like your flooding it try taking out the glow and then turn it over to see how much fuel and or if it even turns
Old 06-10-2007, 04:53 PM
i can turn it by hand but not with the drill
Old 06-10-2007, 04:58 PM
ORIGINAL: aj84
Now thats confusing. If it turns it turns. Whats the difference?
Take out the glowplug and turn it over. What happens then?
Old 06-10-2007, 05:04 PM
right, took out the glow plug and the piston rotates
Old 06-10-2007, 05:07 PM
what now
now turn it over with the drill to be sure you pump out any fuel. Then you should be able to put the plug back and turn it over with the drill again.
Old 06-10-2007, 05:17 PM
cheers i wil give it a try in the morn, one more what fuel should i run it in on, i have 10% as i was told to use it, but i want to make sure
Old 06-10-2007, 05:26 PM
Most of us run 20-30% but it will run on 10%. Just not as responsive and crisp as higher nitro tuned right.
Cheers
Old 06-10-2007, 05:37 PM
Slammed's Avatar
Yeah I use 20% in my Havoc
Old 06-10-2007, 05:59 PM
I think your drill is too weak, get a good 14.4 volt drill and you wont ever have problems turning over the engine with it.
Old 06-11-2007, 08:01 AM
hi
now i now the car turns over id like to put the carb back to factory settings, can any1 tell what they r
cheers aaron
Old 06-11-2007, 08:08 AM
i cant remember out the top of my head, but they are in the manual.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
