Fusion 21 clutch problem???
NC
I fired up my Fusion 21 last week and made some 1/2 trottle speed passes. When I hit the brakes, the car stopped but made a spinning noise. When I hit the trottle, the car didn't accelerate until the spinning stopped and clicked into place. The gears are nerw and I know that's not the problem. After a few more passes, the car stopped all together but the engine kept revving and kept spinning. I know the problem is with the clutch assembly but I'm not sure what to buy exactly to fix it. Please help!!!
FL
RE: Fusion 21 clutch problem???
with the car off the ground give it some gas to see if your clutch is engaging. If it is the problem is not clutch, but somewhere else in the drive train. If it is the clutch, and when you give it gas the clutch bell is not moving , then you need to pull the engine and then the clutchbell to see what is wrong. You could have broken shoes, spring, etc... Let us know what you find.
