Schumacher Racing Discuss all Schumacher Racing products here!
fusion 21 mods ?
Old 09-04-2008, 02:51 PM
jayson415
Default fusion 21 mods ?
hello to all,i have a fusion 21 and i just want to know 2 things =(1) if the pipe on the fusion 28 helps the 21 engine breath easier or theyre the same, and=(2)if is worth to modify the thundertiger 21 with "TNT MODS" since i don't want to change the engine for now.tanks for youre help and keep up the good work
Old 09-04-2008, 09:29 PM
nitrohead5300
Default RE: fusion 21 mods ?
Fusion .28 has a .28 motor.
Old 09-04-2008, 09:38 PM
jayson415
i meant to put the fusion 28 pipe in the fusion 21 , would the change help?
Old 09-12-2008, 08:22 AM
Adam Bailey
From what we've seen it does not help that much, the pipe on the 28 is larger so you get the correct back pressure on the 28, I think that would be to free with the 21 and you would have troubles in tuning the engine because you wont be getting enough back pressure through the pipe.
ORIGINAL: jayson415
Old 12-02-2008, 09:02 AM
ProRCRacer88
You could pull the stinger off the stock pipe and this will give you a power increase but will also be noticably louder. It lets up some of the back pressure. I found out one day when i was driving mines and it came off on its own somehow. But then i decided to leave it off after i seen the car running harder than before.
Old 12-02-2008, 04:39 PM
jayson415
il try that out.tanks
