My first From Plans ?
My Feedback: (9)
Hi,
After a Long time thinking what to build, i have considered start the oldest kit i have, after, finish a TP Sspitfire MKIX started three or four years ago but i shall paint yet, last, desing and build up an extra but finally i decided make my first from plans.
One year ago a think, i ordered some plans from www.airagestore.com cause in a threat some one started build a Duellist and i fall in love, so after ask this guy where the plans were available i ordered some in between was that Pitts Special.
I don´t know who Mark Sirianny and Joe The Marco are, but i´m going try to build it up, any information will be appreciate, i´m going make it light as i can, i´have already an Ultimate and in every landing i´m near the heart attack.
RE: My first From Plans ?
Joe Demarco was one of the regular draughtsmen for Model Airplane News for many years. THis was back when plans were drawn by hand with a big mechanical draughting table and "machine" that moved a set of right angle rulers. And pencils and ink on proper vellum were used instead of CAD.
Did a copy of the original article come with the plans?
Low final weight starts by selecting the lighter grades of balsa for the parts where balsa is used. Balsa comes in a huge range of densities from wood that is as light and punky as foam plastic to stuff that you could safely build houses from. Your job, as the builder, is to select balsa to suit each application so that it is light enough to aid in a lighter final weight yet strong and heavy enough to do the job needed in the structure. This same care for selecting lighter materials that can still do the job will run all the way through the construction, covering and painting of your model. All those few grams involved in each choice will add up at the end.
Best of luck with the build.
My Feedback: (9)
Hi i´m back
Too busy, but don´t give up yet, i´m been working in the fuse, and after thinking and thinking, i´ve decided make some formers looks more a Pitts shape alike, other think i have not clear enough it´s if will be place enough for an engine if i make it as the plans show (i´m thinking in a 120 4 strokes or a 26cc gass), anyway i will get time enough to decide if former 2 is the beginning of the cowl or middle form to make the cowl.
There´s some pictures.
PD. hi Bmatthews, not, with plans come just the plans not any article, and for the information about choosing balsa, thanks, but i knew, anyway here it´s difficult find balsa enough to chose anything. And Ilikebipes and Petronio i hope you enyo´it
Where will you buy the balsa and plywood you'll need ;
Also how do you plan to cut the formers from the wood sheets ?
A scroll saw , for example ;
My Feedback: (9)
Hi Kostas1.
I Know find good balsa and ply it´s difficult, anyway since long a go more than thousand years , here in Spain there ares some places called shops and stores, yes situation in Spain and Greece not good enough but i suppose there may be any shop or store suppling yet
