BT Mosquito Wing Divider
I'm scratch building Brian Taylor's 81" Mossy (finally) from plans I purchased over 10 yrs ago.
I will be using 91 4s; and have a question for some modification help.
The only draw back for this plane is the one-piece wing. Has anyone out there made the wing sectional, either 2 or 3 piece?
I can't seem to find a way to contact Mr Taylor for this so it will be up to someone out there with exprienced re-engineering skills.
Second question is: the plans state reversing one of the engine rotations - is this necessary?
Thanks, John
Thanks, John
RE: BT Mosquito Wing Divider
John, I have made the modifications for a two piece wing, using a 7/8 diameter alum wing tube.
Be glad to send you the rib modifications.
Attached pic of some of the ribs.
Also if you want the ribs laser cut I can quote for you.
See here. http://store.laser-design-services.c...products_id=28
Regards
Bob
Regards
Bob
Hi my mates building one of these and has done all the engineering on the under carriage only to find when build to the spec one servo(or two) it will not retract this under carriage, something about the point of lift ,and Jim is a very accomlished builder of steam engines etc but reckons this as per plan is physically not possible and hes useing 2 retract servos any thoughts would be great
