Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
How to scale up from 1/72 to 1/6 scale?
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 06-15-2012, 12:27 PM
jhunter
My Feedback: (20)
jhunter's Avatar
Default How to scale up from 1/72 to 1/6 scale?
I have the plans for the Karlsson Wildcat in 1/6 scale, along with the retract plans. If I get stalled on the retract construction I will build the Wildcatfish, a float equipped Wildcat. EDO made 1 for Navy testing. I cannot find the float dimensions, all I can come up with are 1/72 scale plastic models. I was the one dreaming about airplanes in every math class I ever took so I have no idea of the formula to go from 1/72 to 1/6. I have not purchased the Wildcatfish kit yet so I do not have the 1/72 float dimension. Appreciate any help you scholars can give me, unless you were dreaming about airplanes too........................
Old 06-15-2012, 01:01 PM
fledermaus
fledermaus's Avatar
Default RE: How to scale up from 1/72 to 1/6 scale?
72 = 6 x 12 so if you multiply any measurement from the 1/72 model by 12 you will have 1/6 scale.
Old 06-15-2012, 02:49 PM
jhunter
My Feedback: (20)
jhunter's Avatar
Thank you very much Fledermaus, glad somebody paid attention in school!
Old 06-15-2012, 08:09 PM
Hydro Junkie
I've seen plans for an F4F-3S "Wildcatfish" as it was called, might even have a set. The plans I saw were for a smaller version, larger than the 1/72 model you're looking at working from.
I found the plans, just don't know if they're what you're looking for
Old 06-15-2012, 10:11 PM
jhunter
My Feedback: (20)
jhunter's Avatar
I have a set I downloaded today for a rubber powered 18" version. And I did find a 3 view and should be able to get the AOA of the wing OK, it is pretty radical compared to the C/L of the floats. Thanks for the response.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
