Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Planning 130 inch Bellanca Aircruiser
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 06-15-2012, 01:09 PM
fledermaus
fledermaus's Avatar
Default Planning 130 inch Bellanca Aircruiser
Starting to work on some CAD plans to build a large Bellanca Aircruiser - 130 inch span, to be powered by a DLE 55. This is the first really large plane I have considered building.
Question about sizing the structural frame members. The fuselage is a typical box truss design. If I use spruce square stock for the truss members, will 0.25 inch be strong enough for this size of airframe, or would I be better to base the design on 0.375 inch square stock?
Old 06-16-2012, 05:43 AM
iron eagel
iron eagel's Avatar
Default RE: Planning 130 inch Bellanca Aircruiser
I have one in that size that uses 3/8 balsa for the frame it is powered by a zenoa G38. Mine is actually the "airbus" version but close enough to call it the same plane I think the only difference is the aircruiser had a water cooled engine that wasn't as powerful as the air cooled version the airbus used. I think they were both referred to as the flying W...
ID:	1772534   Click image for larger version
Old 06-16-2012, 09:27 AM
fledermaus
fledermaus's Avatar
Thanks for the input. I am using the same set of drawings as the basis for my plans. They come from the local historical aviation society, and the Western Canada Aviation Museum is restoring CF-AWR, "The Eldorado Radium Silver Express". I've had a lot of opportunity to examine the airframe over the last several years as they have worked on it.
The Aircruiser still had the radial air-cooled engine - as you can see in your drawing of CF-BTW it had a Pratt&Whitney Hornet R-1690-SIEG supercharged engine (750 HP), while the Airbus used the Wright Cyclone R-1820E (575 HP). CF-AWR was fitted with a Wright Cyclone R-1820 F-32 that delivered 760 HP at 2100 rpm.
Old 06-16-2012, 10:09 AM
iron eagel
iron eagel's Avatar
With those drawings and using cad you will be able to generate a real nice set of plans to build from, your going to have a real leg up building it.
Wow, thanks for the information all I knew is the power plants were different I wasn't sure how. I'd love to see that plane close up.
One note on construction 1/6 ply gussets were used for all of the truss joints and 1/2 solid balsa for nose construction with a plywood firewall. Weight of this 130 inch version is 23lbs (far too heavy) flies what I would call very scale...
I always though it was interesting to note that this airframe was Lindberg's first choice for his transatlantic flight, a very interesting design for the time, not to mention that "Corsair look" from the front.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
