Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Lockheed-Martin F-22 "Raptor"
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 11-09-2012, 05:42 AM
Mike James
Mike James's Avatar
Default Lockheed-Martin F-22 "Raptor"
Hi everybody,
I'm building a new version of Lockheed-Martin's F-22 "Raptor" in 3D, using modo 601, and am nearly finished with the external geometry. There's a follow-along article on my site at http://www.mikejamesmedia.com/raptor_01.html and here are a few renders. (This is not for RC, but for the purpose of creating images and animation.) Enjoy!
ID:	1818794   Click image for larger version
ID:	1818795   Click image for larger version
ID:	1818796   Click image for larger version
ID:	1818797   Click image for larger version
Old 11-19-2012, 02:41 PM
Mike James
Mike James's Avatar
Default RE: Lockheed-Martin F-22
Hi everybody!
I've built (but not detailed) the landing gear bays and weapons bays, and have rigged all the weapons bays doors to open and close. The second image shows some subtle non-square shaping in the weapons bays, showing where the jet intake ducts slightly impinge into the ducts, as on the actual aircraft. I've also added the option of carrying external fuel in wing tanks, sometimes seen when the aircraft has to be ferried a long distance.
Markingsā€¦
At this point, all of the panel lines and other detail you can see on the model are geometry. (No images used to create them.) So, onward to some markingsā€¦ I've exaggerated the colors here, to help me see things clearly, and will correct them later, and for now, am concerned just with the shapes. The first thing I've added is the camouflage pattern on the top of the aircraft, and the vertical fins, along with some more subtle trim around the leading edges of all the control surfaces. I've done that with a combination of item masks and UV maps, so I can edit them at any time.
Next, all the "close-up" markings, like the USAF roundels on the wings, and all of the text warnings around the exterior. (Ejection seat symbols, rescue markings, exhaust warnings, etc.) I'll be placing squadron markings on the vertical fins, emulating the aircraft here at Elmendorf AFB, the "Arctic Warriors", and all of that should go pretty quickly. I don't often have time to do this, so it's not my field of expertise, but I'm finding that with modo 601's tools, it's going faster than I expected, and isn't so difficult after all. Fun stuff!
ID:	1821877   Click image for larger version
ID:	1821878   Click image for larger version
ID:	1821879   Click image for larger version
ID:	1821880   Click image for larger version
Old 11-20-2012, 04:17 PM
Mike James
Mike James's Avatar
Added (Anchorage) squadron markings, production numbers, and the few external "warning" markings on the exterior. I'll be correcting the colors as I go, secondary to the modeling, but I'm pretty happy with the results, so far.
ID:	1822181   Click image for larger version
ID:	1822182   Click image for larger version
ID:	1822183   Click image for larger version
Old 12-02-2012, 06:26 AM
Dago Red
Dago Red's Avatar
watching. i was stationed at elmendorf in the 19th when the first 22 came to base, had pics of them coming in somewhere.
Old 12-05-2012, 07:41 PM
Mike James
Mike James's Avatar
Thank you, Dago!
Here's a brief movie, showing the animated features of the model, as it stands today. (about 8 MB QuickTime)
[link]http://www.mikejamesmedia.com/modo_media/modo_wip/raptor_2013/raptor_271_features.mov[/link]
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
