Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
looking for a soldering station recommendation
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 06-20-2015, 11:12 AM
peterpaul
Default looking for a soldering station recommendation
i need to upgrade current solder equipment. Recommendations for a practical soldering station would be helpful.Fore the most part it will be used to soldering battey connections and small electrical wiring. i have seen ones with the heat gun included...thougts?
thanks
Old 06-20-2015, 11:21 AM
Rodney
That is a tough decision. I have been in the business where soldering is quite important; all types from micro PC to large electronic assemblies and I do not believe there is any one best station. The biggest mistake people make is using to small an iron. While 60 watts might be excessive for really small PC (printed circuit) work, it will really handle 90% of hobby work including PC if you use the right tips. Trying to solder such items as 16 gage wire to Deans with only 40 watts is an exercise in futility for all but the more experienced solderers. If getting a soldering station, make sure that the tip temperature is what is controlled, most of the less expensive one do not, they just regulate the wattage to the system and, if you require lot of energy at the tip, you can wind up with problems. Also, be sure to learn how to use flux as it can really help with the larger jobs.
Old 06-20-2015, 11:46 AM
ByLoudDesign
ByLoudDesign's Avatar
http://www.micromark.com/soldering-and-electrical.html
Old 06-21-2015, 05:10 AM
peterpaul
Thank you for the quick response...your advise was very helpful!
Pete
Old 06-21-2015, 05:11 AM
peterpaul
Thank you...appreciate the advise...pete
Old 06-28-2015, 08:17 AM
T_om
I have been very happy with my Aoyue.
http://www.amazon.com/gp/product/B00...ustomerReviews
Comes with ten tips AND an extra heating element. Dead on temperature control and is 60 watts. Be careful of buying low wattage soldering stations, they severely limit what you can do.
Tom
PS: Hakko tips fit this unit too.
Old 07-05-2015, 09:24 PM
SunDevilPilot
SunDevilPilot's Avatar
I use a weller. Get a really fat tip for soldering large stuff and you'll be really happy.
http://www.amazon.com/gp/product/B00...hps_bw_g469_i2
