Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Scratch building flying boat
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 03-03-2016, 06:22 PM
Roger Gray
Default Scratch building flying boat
I am building a flying boat from my own design. This is the first one I have built with the engine on a pod above the fuse. It is going to be constructed using several different methods, all fun. To be about 100 plus in.wing span. My question is- should the wing and horizontal stab incidence be 0 degrees, and what should be the angle of attack for the engine and does it need to be a few degrees offset to the right?
ID:	2150738   Click image for larger version
ID:	2150739   Click image for larger version
Old 03-04-2016, 07:02 AM
BMatthews
BMatthews's Avatar
For a design of this sort that appears to be a "sort of scale" design I'd suggest you want the wing to be set at a couple of degrees positive to the fuselage keel line as well as the stab. This will aid in coming off the water with a flatter fuselage angle for the takeoff as well as giving you some decalage angle between the wing and tail for pitch stability.
The engine is going to need a fair bit of up thrust to prevent driving the nose into the water. I'd say set it to about +5 and leave room in the way you mount the engine for a good three degrees of adjustment from there. The closer the prop is to being directly above the CG the more angle you'll find is required.
A degree to degree and a half of right would not be a bad thing either.
Old 03-09-2016, 05:12 PM
Roger Gray
Thanks for your reply, I'm doing just as you said. That is about what I wanted to do, maybe not so much on the engine thrust but I can see why it would be best.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
