Allen's Ziroli B-25 101" Build Log
I finally bit the bullet and had to start building a "real" RC plane. In the past I have built several rubber band powered balsa planes, and I cant count how many foamies. Looking for something a little more satisfying I came across the Ziroli B-25 plans. I know it will be a bit harder than what I have done in the past, but what I have read so far is it will be even more rewarding. I will try to keep my blog up dated as I complete this build. I probably won't have anything new on here for a while because I don't plan to buy a kit, so I will be cutting all the formers and stringers by hand. I plan to cut all the formers before I start building and buy the hardware as I go. I already have somewhat of sticker shock as I looked around at prices for engines and gear retracts.
Have you not flown a big gasser yet? This would not be the best path to take. I would suggest you build a big stick type plane to break in the engines, one at a time. This serves two purposes, experience with bigger planes and a cheaper test bed to learn how to deal with gas engines. Just my opinion, but you're taking a big step from the small planes to a pretty big twin. I've had two H9 B-25's. They fly great when both engines are running, very poorly with an engine out. Hense the comment, good luck.
Edwin
Forgot to mention, gassers sometimes emit a black gunk as the rings seat. It goes away after the engine is broke in, but it really messes up a fiberglass and paint job. A big stick can be Mylar covered and cleans up much easier.
Take a look at this maiden. It's was pretty hairy from the way I see it.
https://m.youtube.com/watch?v=olYjGn...ature=youtu.be
Edwin
