Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
What materials to use?
Old 08-20-2017, 08:41 PM
Corsair013
Corsair013's Avatar
Default What materials to use?
I am figuring on doing my first foam scratch build, and it is going to be a HP 0/400 (from a RCM&E plan), but the plan says to use 6mm Depron and I cannot find any suppliers in my country (or any cheap suppliers in other countries).
I am just wondering if 6mm foam-board, or 6mm PVC foam sheets would work as well as Depron, if not, what can I use other than those?
BTW, I live in New Zealand (if that helps at all)
Old 08-21-2017, 04:40 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Not sure what is available in your country ( Depron has seemed to fall off the earth ) but I would take some pink insulation foam and hot wire cut some sheets to whatever thickness I needed. A hot wire bow is very easy to make. Use this stainless steel wire and for power, a car battery charger will work. A bit crude of a setup but with some experimenting will yield good results.
Old 08-21-2017, 02:03 PM
Corsair013
Corsair013's Avatar
thanks, Ill give it a shot!
Old 08-22-2017, 09:40 AM
mgnostic
mgnostic's Avatar
Hobby King lists a variety of foam that it describes as a depron substitute. Best of luck on the build, I'd love to see it.
Old 08-24-2017, 07:09 PM
Corsair013
Corsair013's Avatar
thanks! I will be making forum post/build log about it.
So stay tuned!
Old 08-25-2017, 03:18 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Pink foam cut down to 6mm would have just about Zero strength,, that's a bad recommendation IMO
Old 08-25-2017, 05:56 PM
speedracerntrixie
My Feedback: (29)
Don't be so sure. The 150 XPS seems to be the most common hardware store variety and where did I say 6mm?
ID:	2229449   Click image for larger version
ID:	2229450   Click image for larger version
Old 08-28-2017, 02:39 PM
scale only 4 me
My Feedback: (158)
6mm thickness is what the OP was looking for,,
Old 08-28-2017, 05:07 PM
speedracerntrixie
My Feedback: (29)
You are welcome to read it a second time.
Old 09-10-2017, 07:31 AM
speedracerntrixie
My Feedback: (29)
Found this on Facebook today. Looks like pink foam is a very viable material.
https://m.youtube.com/watch?v=fhbZsc...ature=youtu.be
Old 09-10-2017, 06:14 PM
ibuild
ibuild's Avatar
The "pink foam" is actually available in all sorts of densities if you source it. It's basically "high density floor insulation foam" (extruded). Standard may be #250, I cut my foam core wings in #500, I have to order it especially though. I thought that was worth mentioning. A common in Imperial may be "high load 60". Yes - there is a great difference in the density of foam available, remember that the higher density (harder) the heavier it gets.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
