Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Gear driven pitcheron glider/E-glider
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 10-07-2021, 07:06 AM
ECHO24
Default Gear driven pitcheron glider/E-glider
Below is a PDF flyer for a RC glider that uses 3D printed gears to control the wings. The fuselage, gears, and
V-tail mount are 3D printed. The wings are conventional balsa covered foam cores and the tails are balsa.
If you click through to the Etsy link there is a short video clip from a tail cam on the E-powered version showing the action of the wings.
File Type: pdf
Old 12-03-2022, 08:22 PM
ECHO24
I redesigned the plane to use 3D printed wings and eliminated the foam cores. I put the original STL files free on Thingiverse if anyone is interested and can make their own wings
https://www.thingiverse.com/thing:5678847
Servos are Corona DS-238MG (2). Spar is 8mm X 250mm and aluminum tube.
Old 12-28-2022, 02:58 AM
Sebastien
Default I'm going to build one
Can you please tell us more about the wing ? chords, position of the spar ?I'm printing the fuselage parts, I'll be building foam core wings with various airfoils...
Old 12-28-2022, 12:16 PM
ECHO24
I sent you a PM with the wing dimensions. I tried uploading the PDF assembly guide which includes the wing plan and instruction but for some reason can't attach it here,
