Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
testors paint on foam?
Old 04-26-2002, 06:26 PM
Default testors paint on foam?
i was looking for a paint i could paint right on foam without it melting it... i tryed testors enamel and it does not melt the foam at all and it was sprayed right on the bare foam... just curious what testors dont have in the paint that other paints do that melts the foam?????also what would be better to use as the finish? testors acrylic or enamel testors?
Old 04-26-2002, 07:58 PM
My Feedback: (32)
k_sonn's Avatar
I have used the testors model master paints on my planes. It is not fuel proof so you have to spray a fuel proof clear over it. I use top flite flat clear lusterkote. The difference between the enamels and the acrylics, besides water clean up for the acrylics, is that acrylic can be painted over other paints even if they aren't acrylic, but only acrylic can be painted over acrylic. This leaves the question of what clear do you spray over acrylic that will not yellow. Hope this helps.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
