Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Super Strikemaster
Old 04-18-2011, 03:59 PM
  #176
Jim_Purcha
My Feedback: (8)
Default RE: Foam Strikemaster
Why don't you try the short kit from eureka models. Laser cut balsa and foam wings.
Jim
Old 04-18-2011, 06:30 PM
  #177
cwesh
Plans for the original are still around!
http://www.rcmplans.com/index.php?ma...oducts_id=1375
Later!
Old 02-15-2013, 09:10 PM
  #178
Blade47
Blade47's Avatar
I see you here Don :-)
Peter
Old 02-15-2013, 09:44 PM
  #179
nitro wing
reminds me of the travel commercial
" I can see you Karl ! "
Old 02-15-2013, 10:23 PM
  #180
hattend
My Feedback: (20)
ORIGINAL: Blade47
Peter
Hi Pete, I am still here but only as a spectator. I'm still in the same boat as I was when I had just left Galena. My airplane stuff is in California and I am here in the Alaska bush with nothing to do.
My plan is to slowly start getting building material sent up here. My main need right now is a building board. I have 2 in California but it'll cost a fortune to get them up here. I would love to start building with / against you again. Maybe next winter.
If you still have your Strikemasters available, can you measure the tailplane span on either the small one or the Super? Modeler bacplus would like to know.
Stayin touch, buddy...we have to build again!
Don
Old 02-16-2013, 05:53 AM
  #181
Blade47
Blade47's Avatar
Yeah ok Bud I will get to measuring the "T" this morning and get the info in here ..I guess I had better measure the Rudder post as well ...Hmmm
Old 02-16-2013, 11:15 AM
  #182
hattend
My Feedback: (20)
From 2 years ago but I had forgotten about Eureka Aircraft (They bought out the company who makes the Super Strikemaster wing cores)
Thanks Jim....two years late!
Don
ORIGINAL: Jim_Purcha
Jim
Old 09-15-2013, 05:10 PM
  #183
rhomco
Way back in 1988 I enlarged the strikemaster to fit a .60 size Brushfire pattern plane wing and stab. It looked great and flew even better with that swept wing. Here I am 25 years later and I am doing it again in both .60 size and 1.60 size.
Rob
Name:	Strikemaster .60 001.jpg
Old 09-23-2013, 07:36 AM
  #184
hattend
My Feedback: (20)
Looks great, Rob!
Old 12-28-2015, 10:31 AM
  #185
Grumpy2
Had a partially built plane given to me that had been in a basement for about 15 years. It started as a IC engine but I am building for electric. Am in the processing of glassing the wing, the second coat of epoxy just went on. I like the above pictures, it makes for a beautiful finish, Mine will be a similar paint scheme..
The previous owner had started the wing with flaps which I will continue on with. Like was mentioned above (make sure you have plenty of sandpaper.
Steve M
Georgia
Old 05-13-2018, 11:51 AM
  #186
hattend
My Feedback: (20)
Bump to the thread!
Don
Old 03-23-2020, 02:07 PM
  #187
hattend
My Feedback: (20)
Default Pete, you still there?
Hi Pete. You still building and flying in Whitehorse?
I'm no longer in King Salmon, I have moved to Kotzebue, AK. Just checking in.
Don
Old 03-23-2020, 02:19 PM
  #188
rhomco
Default My latest version of the old Strikemaster.
This is the latest version of the old Strikemaster. The fuse is enlarged to 64 inch length. The flying surfaces are from the Brushfire Pattern plane. The wing is 66 inches. The nose and vertical stab is modified to resemble the F-8 Crusader.
OS 65 AX power.
Old 03-23-2020, 02:24 PM
  #189
hattend
My Feedback: (20)
Thumbs up
Now, that looks AWESOME!!!
If I build another, I may just have to copy it.
Don
OS 65 AX power.
Old 05-31-2020, 02:34 PM
  #190
Wizardofflight
Looks like a turo-porp upgrade. Looks great!
OS 65 AX power.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
