Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Props on deltas
Old 07-05-2004, 05:41 PM
>X<
Default Props on deltas
How can you put a prop at the front on a delta type plane?
Old 07-05-2004, 06:22 PM
dicknadine
Default RE: Props on deltas
suggest that you modify the nose to accept the motor. its a good Scratch design effort. will show you what can be accomplished when you try and learn out of the box. dick
Old 07-05-2004, 06:58 PM
>X<
Cool... Thanks
I could make the nose flat
ive thought also that maybe i could mount the moter using some square guttering and inside there i can make places for the radio equipment to go also, so mounting the motor would be cool
Old 07-06-2004, 10:19 PM
Dsegal
This is a Reflex delta I once had. The fuselage and engine mounting are conventional.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
