Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Starduster Too by Dario Brisighella
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 01-20-2014, 07:13 PM
A7Bldr
My Feedback: (40)
Jeff, in case anyone is looking for plans for this beauty, here is a quote over on the Scale Forum from Dario himself:
It is very gratifying to see how IMAA has grown over the years and I’m happy to say that I had a hand it getting it off the ground way back then when I was a very early founding member. While I’ve not been active in R/C for many years, I still attend the local IMAA fly-ins whenever possible. It’s nice to see other old-timer Giant-Scale modelers as well. What is amazing to me is the simple fact that even after some thirty years or so, I still receive inquires about my giant scale plans every so often, even though the hobby appears to be more interested in ARF's, than enjoying the thrill of that first flight on the model you have built from a set of plans and a pile of spruce and balsa. Where am I going with this well, I’d like to announce that the scale plans I started offering so many years ago are still available For a while my son was dealing with them, before he passed away The masters are once again in my hands and I will continue to offer them for sale.
The R/C Giant Scale plans I have to offer are:
The home-built STARDUSTER-TOO, which is done in 28% scale and has a wingspan of 80 inches. Its butterfly shaped wings make it a real stand-out at any flying field. The plan-set consists of three sheets or some 80 square feet of paper. This model was designed right off the original building plans that my good friend Howard Ehellers and I built and flew the real thing and still have those plans.
The home-built SKY-BOLT, this is done in 26% scale and has a wingspan of 78 inches. The model was designed right off the actual full-scale drawings, which Lamar Steen allowed me to use. The plan set consists of three square feet of heavy paper.
The WACO ARE model was taken from some partial factory plans as well as measuring the aircraft itself, which at one time belonged to the New Your City Daily News, and was used as a camera plane. The scale is 21% and the wingspan is 87.25î. The plan-set consists of three sheets or 58 square feet of heavy paper.
I feel confident that many of you members have actually seen one or two of the models at a fly-in or two. There certainly have been a lot of plans mailed out all over the world, over the years, or maybe some have been used for wallpaper. The thing I regret is the price I have to charge for them. They don’t do Blue-line prints any more, but rather make black-line copies and those costs have doubled. The costs for the shipping tubes and the shipping itself followed suite. The plans are $75.00 each, which includes shipping in the USA or Canada.
Dario Brisighella Sr.
Email; [email protected]
Phone: 414-762-7155
Old 01-21-2014, 02:28 PM
jefff
My Feedback: (8)
That is great that he is back selling his plans. I got mine from the AMA plans service. The AMA must be licensed to sell them.
Old 01-24-2014, 04:37 PM
jefff
My Feedback: (8)
I just finished getting the landing gear ready to silver solder. I may Tig weld the 1/4" support rod to the landing gear rod. The aluminum block that hold the rods in place also are drill jigs for the screws that hold the gear to the fuse. The rods that go through the board are shocks. Compression springs go on them inside the fuse. The wood block that the rods go through will be glued into the inside of the fuse.
ID:	1961716   Click image for larger version
Old 01-25-2014, 08:13 PM
flyboy61045
My Feedback: (10)
flyboy61045's Avatar
Looking good Jeff
Old 01-25-2014, 09:07 PM
BILLYDSRC
BILLYDSRC's Avatar
Nice looking gear there! Can't wait to see her fly
Old 01-29-2014, 11:29 AM
  #31
jefff
My Feedback: (8)
I just finished the cabanes. I used steel for the mounts and muisic wire for the cabanes. I silver sodered everything. The alignment came out pretty good. Horizontal and upper wing at 0 degrees. Plus wing tips to the tail is even. The lower wing has +1 degrees that I have to change to 0 degrees.
ID:	1963160   Click image for larger version
ID:	1963161   Click image for larger version
Old 01-29-2014, 11:59 AM
  #32
TBFlyer
Looks like they came out perfect! Nice job.
Old 01-29-2014, 04:03 PM
  #33
A7Bldr
My Feedback: (40)
She's really taking shape! What a good thread for anyone contemplating one of these.
Jim
Old 01-31-2014, 10:27 AM
  #34
jefff
My Feedback: (8)
Finished covering the aft fuse and the turtle deck. It is only rough sanded. Before I put the covering on the front of the fuse I want to set the fuel tank , batteries and servos for the El.,Rud. and throttle. It will make it a lot easier to do now.
ID:	1964139   Click image for larger version
Old 01-31-2014, 09:37 PM
  #35
BILLYDSRC
BILLYDSRC's Avatar
Looking Great Jeff!!
Old 02-10-2014, 06:42 PM
  #36
A7Bldr
My Feedback: (40)
Jeff, any updates? I finally got my short kit and have begun work. Do you have any photos of how your wingtps are built? The RCM version uses huge balsa blocks.
Jim
Old 02-11-2014, 05:35 AM
  #37
jefff
My Feedback: (8)
Hi Jim, glad you finally got your short kit. There is still plenty of Winter left to work on it. From the pics the center ply spline goes around the wing tips. I used balsa blocks from the leading edge to the main spar. From the spar to the trailing edge is just balsa strips.
I have had club matters that has taken a lot of my time. But I am starting to install servos in the fuse and run my push rods ( steel stranded cable and in nylon tube ). Then I will put the rest of the formers on and sheet the rest of the fuse.
ID:	1967591   Click image for larger version
Old 02-12-2014, 04:11 PM
  #38
A7Bldr
My Feedback: (40)
Thanks Jeff, that is helpful. My tailfeathers are done and I'm on to the wings.
JIm
Old 02-18-2014, 09:43 AM
  #39
jefff
My Feedback: (8)
Jim here is a deal. A friend sent it to me. To late for me. Maybe somebody interested in building the 80".
http://www.ebay.com/itm/STARDUSTER-T...item35d22f4ff8
Old 02-18-2014, 02:44 PM
  #40
A7Bldr
My Feedback: (40)
Yeah that's a good deal if it sells for that amount. I'm too far into this one to stop and start another, but I'll keep an eye on it.
Old 02-26-2014, 07:38 PM
  #41
jefff
My Feedback: (8)
Finished installing the servos and push rods for the el. and rud. I used carbon fiber push rods instead of cable push rods. Installed the servos for the ail. Also hinged the ailerons. I think I will hold off covering the rest of the fuse until I install the engine. If anybody knows where I can buy a 3 degree wedge for the engine mount let me know.
ID:	1972890   Click image for larger version
ID:	1972891   Click image for larger version
ID:	1972892   Click image for larger version
Old 02-27-2014, 07:02 PM
  #42
RCplanman
My Feedback: (16)
Originally Posted by jefff
Front formers epoxied in place. Just finished epoxing the firewall and landing gear plate in place. Next I have to pull the sides together and install the cross braces.
Jeff, Congrats on a good plane to build from the BEST plans I;ve had the pleasure to work with. I built one 3-4 yrs ago. Prettyest plane I ever had [ I'm 85 ] But it never survived the maiden.fllight. WT.was 17lbs with a G-38 for power.It was under powered.!!Take the advice of the early post and correct the Hor. stab.
I'll try to enclose a photo.I'm not too good w/ the computer.
Good Luck.
Bill Rogers
rcplanman
Old 03-01-2014, 05:26 PM
  #43
jefff
My Feedback: (8)
Finished the landing gear . The 12 mounting holes lined up good .
Old 03-01-2014, 05:37 PM
  #44
jefff
My Feedback: (8)
Bill, I was planing on putting a DLE 55 in it. Hope that will be enough power. That really hurts to lose it on the maiden flight. It is to late for the hor. Stab. I made it per the plans. What can I expect how it will fly?
jeff
Old 03-14-2014, 03:10 AM
  #45
jefff
My Feedback: (8)
Finished installing the servos and pushrods. Still need to install the engine and throttle servo.
ID:	1977867   Click image for larger version
Old 03-23-2014, 01:41 PM
  #46
jefff
My Feedback: (8)
I made a 3 degree thrust wedge from aluminum for the engine mount. Glassed the firewall. Installed the shock springs. I am installing the ignition close to the firewall. The cowling goes over about 2" of the top of the fuse. I can leave a access hatch to get to the ignition if needed. The two A123 battery packs will go into the foam pockets behind the firewall. I am a lot closer to haven it ready to cover then I thought I would be at this time. I hope that Solartex yellow matches the full scale one! Then I just have to spray the black trim color.
ID:	1980850   Click image for larger version
ID:	1980851   Click image for larger version
Old 03-23-2014, 07:47 PM
  #47
A7Bldr
My Feedback: (40)
I thought you'd be flying it this summer.......looks like it will happen!
Old 09-04-2014, 03:41 AM
  #48
damifino
damifino's Avatar
Default Update?
Any progress on this? Ready to see some covering!
Old 09-04-2014, 01:47 PM
  #49
jefff
My Feedback: (8)
Sorry it has been on the back burner ever since the weather broke. My priority in the summer is it fly. I also been trying to get my Byron Corsair ready to fly. I do have it ready to paint. I covered it in Solartex. I just had the paint matched to Ultracote Yellow at Lowes. I am going to try and get the base cote done in a couple of weeks.
ID:	2028953   Click image for larger version
Old 09-29-2014, 06:42 PM
  #50
jefff
My Feedback: (8)
Got the Yellow sprayed today. Have to do the Black trim next and Gloss Clear cote.
ID:	2036240   Click image for larger version
ID:	2036241   Click image for larger version
