Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Landing gear size
Old 01-11-2002, 07:07 PM
Default Landing gear size
Without being to thick and end up heavy, how thin of aluminum can be used for a 9 pound plane? I have seen some 3/16" but that just seems to stiff.
Old 01-11-2002, 11:27 PM
Default Aluminum L.G.
To some extent the thickness would depend on how long the legs are.
Generally, for a nine pound airplane 1/8 aluminium would be adequate. The grade of aluminium should be 6061-T6. This spec gives a material that has a certain hardness and therefore springback. Any softer material than this is not suitable.
Ed S
Old 01-11-2002, 11:49 PM
Default Re: Aluminum L.G.
Ed S
Thanks Ed, From the axle center to the top flat of the gear is 4.5", 7.5" across the top flat, and 16.250" wide at the axles.
Ray
Old 01-12-2002, 12:56 PM
Default Landing Gear
Ray,
!/8 thick aluminium will be suitable for a LG the size you indicated. I have a LG slightly smaller than yours. It was used on a model that weighed just over nine pounds. It is solid.
Ed S
Old 01-12-2002, 11:14 PM
Thanks Ed, I was hoping it would . I will give it a go.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
