Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
How to cut holes in ribs?
Old 01-23-2002, 02:30 PM
Default How to cut holes in ribs?
What do you guys use to cut holes in ribs?
I'm mostly talking about the holes needed for the phenolic tubes used in giant scale wings (like 1.5" diameter). They have to be accurate and neat.
Also, what about holes for the servo wire tubes?
In the past, i've used forstner bits with my drill press....but I've never been satisifed with the end result in balsa. it often tears out and makes a ragged hole.
David Soniat
Old 01-23-2002, 07:30 PM
Hircflyer's Avatar
Sharpened brass tubes turned slowly seems to work pretty well.
Old 01-24-2002, 01:50 AM
mselby's Avatar
dremel with fine permagrit bit
Mike
Old 01-24-2002, 05:22 PM
I have used a hole saw in my drill press, this requires the balsa to be "sandwiched" between two scrap pieces of ply. Put the "sandwich" under pressure while feeding the holesaw through it.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
