Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
I have an odd question ?
Old 01-26-2002, 12:35 AM
Default I have an odd question ?
what material is used for turbine exhaust ducts ? the reason i ask is that i wanted to build a sort-of-VTOL aircraft, it would be huge, and i wanted a pair of turbines for lift and a pair for foward flight. It is my own design and I have the duct work figured out , I just wanted to know what material i should use for the exhaust ducting and exit shroud
thanks
Old 01-26-2002, 08:28 AM
Mike James's Avatar
Default Exhaust ducts
Be aware that I'm not a jet flyer, so you probably want to talk to an expert. However, I do a lot of reading, and believe that most turbine guys use either stainless steel, or a heat resistant ceramic for the exhaust area.
It's a whole different deal than ducted fans!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
