HOW DO I CONNECT?
HOW DO I CONNECT?
Well, it's down to the wire with this ARROW delta wing I've been working on.. I found a DUBRO KWIK-FILL fuel valve in my junk box But typical of anything that's been sitting in a drawer for who knows how long --- there are no directions with it.
Can anyone help me how to hook up this system?
marwen1
marwen1
GA
RE: HOW DO I CONNECT?
ORIGINAL: marwen1
The connector where the air comes out is where the fuel tank connects to the filler valve.
The other connector is where the line going to the engine connects.
Those things go bad. The spring loses tension, and the button that is pushed in by the fueler probe -stays in-, cutting off the fuel line to the motor when it's removed.
Watch for that.
Watch for that.
I kind of thought that would happen. Even though these things are about $15.
It's really hard to insert the probe so i would think that it would be a half decent idea to to place a few drops of 3in1. That should make the ins & outs a little easier.
This housing that I am installing it in is just balsa but its been laminated about three times. The overall strength is uo to par but the hole for it is 3/8" and only about 1/4" or so long. Far too short to do and good so I mouted a 1/8" ply x 1 1/2" square behind a 5/8" hole. That allows my tools to fit right over it and it noe becomes a recess.
I took a couple of shots to kinda show what I mean
Hey Fred: This is the ARROW you & I were talking about
Marshall
Marshall
GA
ORIGINAL: marwen1
ORIGINAL: Campy
I have had nothing but problems with those type of fuelers - the longest I have gotten out of any of them was one season before the leaking started.
For long term durability and reliability go with a 3 line system.
marwen1
